Oh no...plenty of wire! I have the charger and the plug listed on our site: https://www.opentrailcreations.com/collections/recommendationsNice! Did you have to extend the 120v wiring any, or is the combined length of the leads enough?
Unlikely, unless you use a long, low quality, small gauge extension cord.... that is unless the combined operation of the Genius and the block heater exceed 15A/120V...
Is that staying under your hood all the time? How is it dealing with heat?Same. Ran one on my 22 and now one on the 24. No issues. View attachment 212010
It works great.Is that staying under your hood all the time? How is it dealing with heat?
Isn’t the temperature under the hood when the motor is running well above the storage temp of 140? And do you leave it mounted to the battery like that?It works great.
Line Voltage: 120V to 240V AC
Frequency: 50Hz to 60Hz
Operating Temperature: -4° to 104°F(-20° to 40°C)
Storage Temperature: -22° to 140°F(-30° to 60°C)
Relative Humidity: 0 to 95% Non-Condensing
No issues.Is that staying under your hood all the time? How is it dealing with heat?
The NOCO Genius 10 is a 10-amp charger/maintainer, offering roughly double the charging speed of the 5-amp Genius 5, making it ideal for larger batteries (up to 230 Ah) like those in RVs or trucks. The Genius 5 is better suited for smaller batteries (up to 120 Ah) in cars or lawnmowers. Both are smart chargers for 6V/12V lead-acid and lithium, but the Genius 10 adds a 12V power supply mode.Any particular reason you go with 10 amp charger over the 5 amp if you are just using it more as a float charger when the truck is parked for an extended period of time? I’m at just short of stupid when it comes to stuff like this but I would think a 5 amp charger would suffice if you were just trying to keep the battery topped off.
If it were a dead battery that you were trying to “jump” and bring back to life I can see the 10 amp but what am I missing?
It works great.
Never bad to be cautious when it comes to electronics. BTW, I had to get my manual to look up other specs and found that the Gen Pro and Gen series has a maximum operating temp of 122F. Storage states 60C (128F) average and 80C (160F) maximum.Isn’t the temperature under the hood when the motor is running well above the storage temp of 140? And do you leave it mounted to the battery like that?
Overall I’m a fan of this but want to understand the feasibility.
Thanks for the information on this. I agree that air movement is going to be important, so I think the only challenges will be sitting in traffic or driving through the desert in the summer. I think when it comes to those types of road trips, I will probably just take it apart and keep this more for home and short drive maintenance. Overall, a really great setup.Never bad to be cautious when it comes to electronics. BTW, I had to get my manual to look up other specs and found that the Gen Pro and Gen series has a maximum operating temp of 122F. Storage states 60C (128F) average and 80C (160F) maximum.
Under hood temperatures are not likely to exceed max temperature specs since air circulates throughout the engine compartment from outside. You can always contact the manufacturer for direct answers, but I know many people that use these mounted under the hood without issue, including myself. If you were still concerned about max temperature, you could always mount it lower than the battery. There's a nice flat area behind the headlight you could fit it into.
Here's a cool video on comparison of chargers and their operating temperatures shown towards the end of the video.
When you mounted it to the lower grill housing, did you just use a taper bit and drilled a hole to feed that through? It looks like it then uses self tapping screws? Its no longer for sale on amazon, so gonna have to look elsewhere for it.I use the 5 amp and it works great!
This is the one: https://www.opentrailcreations.com/products/recommended-gen5x1-marine-battery-chargerWhen you mounted it to the lower grill housing, did you just use a taper bit and drilled a hole to feed that through? It looks like it then uses self tapping screws? Its no longer for sale on amazon, so gonna have to look elsewhere for it.
I love that idea and I just ordered a two way plug-in like that. I’d like to put it on the left side of that tow hook because my winch hook is connected to that one and would cover up where you have it. It would work on the other side of my winch also but that plastic panel is loose because of the winch install and so that’s a no go. The bummer thing is my number one spot on the left side of the tow hook. I don’t think that the plug-in adapter is going to fit there because it’s too shallow and there’s a metal bumper support behind there.
