@Canyon Trekker is correct, but i would call the Forscan change "nice but not necessary". If you plan to use Forscan anyway to tweak a few things, might as well change battery type to AGM while you're at it.
This is a multi-faceted argument when it comes to specs of the batteries and charge systems. Most talking points point out the obvious, low or high voltage on an AGM won't work. This statement is true and a "safe" blanket statement to make if you don't know what you're looking at in a particular situation. Most dwell on a "charger", not a vehicle charging system. They operate differently. (Another lengthy discussion for some other time) I found only one video that shows why you "can't" replace an FLA with an AGM, due to the alternator not putting out enough voltage to maintain the charge. It's a valid point. But not for our trucks.
There are plenty of videos out there telling you that you MUST use an AGM "
charger" when charging an AGM battery but fail to correlate it to a vehicle charging system. (Because most vehicle systems charge at 14.5V, which is adequate and safe for AGM)
I would be curious if
@UpInSm0kE does this change in Forscan, does the initial cycle charge voltage change, and does the float voltage change from the non-AGM setting. If I recall,
@BroncOh reported that after he made the change in his truck, there was no difference. For an X2 battery, the cycle service voltage requirement is between 14.4 and 14.8; and the float is 13.5 to 13.8. I believe my truck is right in this window in the "normal" setting.
I wouldn't be surprised that the only thing the AGM setting does is change the monitoring "thresholds" of the battery to determine a failing battery. If someone could prove differently, I'm all ears.
By the way, if you look up a replacement battery at Batteries plus for a truck that had an original FLA, (such as the 22 like mine) it directs you (as an alternate to the FLA) to the Duracell AGM and the X2 as the high-performance replacement. It also provides a 4-year limited war. for the Duracell, and 4 year non prorated warranty for the X2. Sounds like a pretty safe bet to me.
Depending on the computer in some vehicles, one possible reason the AGM setting might be preferred is that if the charge voltage is less than 13.8 for the FLA, an AGM may never reach full charge, and the setting may allow a higher voltage out of the regulator. (but I doubt it) But even a slightly higher voltage than 13.8 has the ability to bring the battery back to full, albeit at a very slow rate. (That's how a trickle charger works) That's why an external maintainer is the winner in this case.
Batteries plus ad.
