Sounds like the XL80 has a better light throw & more lumens for a light mounted higher up as in on the A pillar for distance & is the way to go
Wonder what the candela is for the XL80 & LP4
But it seems if you couple BD’s 2 light fog light pocket light package with the XL80’s on the A pillar you have a lighting system that works in 98% of all weather & road conditions
@Busa Dave @Vee8Thunder @TremorJohn I'll update you when installed. My truck has a build week of 11/22...coming up!
Funny, I look odd measuring grill areas on Lariats that I can find on the lots around here. What did it for me is watching this video - at the ~50 second mark and will give the needed depth to mount the bar.
Thanks @Nick@ApolloOptics!
Thanks for posting the video.. I am thinking the OX6+ bar may be too deep. Are you planning on using the + or the regular version?
What @ChemLab said…
I want to do the same thing. Take lots of photos and show your measurements. The OnX6+ 40inch curved is what I’d like to run on the bumper as well. I’ve run some bigger lights on the front in the past, you wouldn’t think it would cause cooling issues but my previous truck ran higher temps after installing round lights On an NFab bar. I figure if I want a little more distance directly in front I’ll try A Pillar lights.
First on the “light list” is the 40” arc bar and the Baja designs dual fog light kit.
I'm glad it wasn't just me. It took me way longer to install 6 bolts than I'd have anticipated.So would the bracket be sold or would you guys swap the brackets from those who bought this kit already. It was a pain in the butt to get them on.
The XL Linkable appears to be "Crowning" in the middle? The center pod seems higher then the end pods...I have this light bar on my 2021. Also ordered another one for my 2022.
Love all of the Baja Design stuff, always super high quality stuff.
Does not block the camera as much as you would think.
View attachment 38916View attachment 38917View attachment 38918View attachment 38919View attachment 38920
Slightly. The middle lights are also angled up more, and the outer are angled down.The XL Linkable appears to be "Crowning" in the middle? The center pod seems higher then the end pods...
I've been really happy with it. Ordered another one for my 2022 that just arrived.
How was the install with the winch?Slightly. The middle lights are also angled up more, and the outer are angled down.
Had a local shop do it, he didn't have any issues, but he never doesHow was the install with the winch?
I had an 40" Onx6 Dual Control on my old rig and absolutely loved it.I agree. I run a similar setup on my truck. XL80s on pillars with amber lenses, 40" OnX6+ Arc in bumper, and a pair of amber Squadron Pros.
You're welcome! I have 40" OnX6 Arc bars in stock.
There are only 3 version of the Arc bar available: OnX6+ Arc, OnX6 Dual Control, and OnX6+ Racer Edition. The regular Arc has been discontinued.
We'd be glad to help you with both! I've got both in stock right now depending on your fog options.
That makes perfect sense now. Thanx for that info. I didn't think there was that much adjustability in those when linked. That's great!Slightly. The middle lights are also angled up more, and the outer are angled down.
The XL Linkable is taller so it will sit higher and may need some adjustment/modification to make it work.I had an 40" Onx6 Dual Control on my old rig and absolutely loved it.
I was looking to upgrade from the Linkable XL kit to an ONX6 ... any idea if I could reuse my existing brackets from the XL kit?
Is there a better mounting kit for an Onx6? I love that the XL Kit brackets mostly mount up well using stock holes... but interested to maybe make a move to an Onx6.The XL Linkable is taller so it will sit higher and may need some adjustment/modification to make it work.
View attachment 38445No issues blocking front camera. Mounts are freaking solid as a rock.
Ran along roof rack and dropped down between bed and cab then hooked to upfitter harness under hood.How did you run the roof lights into the cab of the truck?
I believe that this time last year it's suggested retail price was $1,649 but with the group buy and black Friday rebates I think I paid around $1,100. Can't remember the exact number. I love them and would buy again. Out here in the middle of nowhere Missouri, I use them all the time.I was starting to do a little research on the linkable kit and then read it was discontinued or something and now I see its back on Baja's site and is nearly $1700... Was is that expensive the first time? For some reason I was thinking it was around $1100
