Baja designs 7-LIGHT XL LINKABLE LIGHT install question:
I was hoping to keep the two plastic end caps intact. I thought I saw a photo where someone did. It just looks better that way and not use the velcro.
Mine looks oem using the velcro. I guess the only area that would not is right by the grill.
How would you hook up this type of harness to the upfitter switch? View attachment 154004
Look like you received the toggle switch harness and not the upfitter harness, slightly different part number for the two kits.
Toggle Switch: 447732 - https://apollo-optics.com/products/...able-kit-standard-harness-baja-designs-447732
Upfitter Harness: 447732UP - https://apollo-optics.com/products/...linkable-kit-w-upfitter-baja-designs-447732up
You have a few options:
Option 1: Remove the plug off the light, Make your own Weatherpack connector. White wire to upfitter, black wire ground to chassis.
Option 2: Use the harness you have. The blue wire is the switch wire. Ground the black wire.
Option 3: Purchase the upfitter harness to make it all plug and play. https://apollo-optics.com/products/ford-upfitter-wiring-harness-onx6-s8-baja-designs-640094
Great info!!! For $19 I’d go with the final and best option personally.
Thank you guys! I have ring terminals and butt connectors, I think I’ll cut off the relay and switch and go with option 1.
To use that harness, you will need to modify it to make it work. You will need to cut before the relay. You can disregard the relay and battery connections. You will have a black and white wire. Black will be your ground and white will be your power. You can also purchase https://www.bajadesigns.com/product...ring-harness-universal/?vid=148893&sku=640094 for no modifications needed.
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
Best,
Thank you Brahian. I checked the length and it will fit after I cut the relay out. I'll put a ring terminal on the ground and a butt connector to the upfitter, that should be just fine. Thank you for your response, great products!
Can anyone who’s been using this setup for a while comment on how much bounce/flicker there is from the lights while driving offroad? I’m a little concerned that this mount setup might not be rigid enough offroad compared to mounting on a push bar or similar.
Mine is rock solid. I'm at the ranch all the time and it's been great
What he said. Zero movement, it's like daytime with them on.
The setup is rock solid because there's an additional support bar in the middle for added rigidity, along with the robust side mounts.
We do have these kits in stock and ready to ship for both the 20-22 trucks as well as the 23+ trucks.
20-22 Trucks: Baja Designs Ford XL-Linkable 7-Light w/ Upfitter Bumper Light Kit - Ford 2020-22 F-250/F-350/F-450 Super Duty
2023+ Trucks: Ford Super Duty (23+) XL-Linkable Bumper Light Kit
If you have any questions on installation or if you'd like more information or a price quote, feel free to send me a message and I'll be happy to help.
I didn’t realize that there was an additional support in the middle. That is great to know. Thanks everyone for the input!
