Anymore news on the 2023 brackets?
@Baja Designs
@Baja Designs
Yeah i was really hoping to get these over Black Friday on sale…. I guess now I don’t need them until spring.Anymore news on the 2023 brackets?
@Baja Designs
Kits are scheduled to come out 1st quarter of 2024.Anymore news on the 2023 brackets?
@Baja Designs
Sorry to revive an old thread, but can someone tell me the secret to getting the two top bumper molding pieces off of a 2022? I've tried using 3 different trim tools, and even had a long flat head screwdriver on the bottom clips trying to press them out.
I'll give that a try. Hopefully my needle nose are long enough. Thanks!I used a pair of needle nose pliers to pinch the bottom plastic tab together while using a trim removal tool to essentially pry upwards at the same time.
For what it's worth - I broke both the tabs off during removal. It goes back together with Velcro, so it didn't matter.I'll give that a try. Hopefully my needle nose are long enough. Thanks!
Glad you said that, because I just broke all but one tab on the driver side one. Now to try the passenger side.For what it's worth - I broke both the tabs off during removal. It goes back together with Velcro, so it didn't matter.
Yep - the Velcro will be your friend.Glad you said that, because I just broke all but one tab on the driver side one. Now to try the passenger side.
That looks exactly like my bracket on the passenger side for the linkable kit. I also included the driver side for reference.
FWIW I cut mine - not sure how I could have made it work without cutting. I braced it in a vise (wrapped) and cut the area off they recommended.@yArdbird , did you install those lights without cutting the end pieces? If so, any issues and tips on how? I like the idea of no cutting.
I was hoping to keep the two plastic end caps intact. I thought I saw a photo where someone did. It just looks better that way and not use the velcro.FWIW I cut mine - not sure how I could have made it work without cutting. I braced it in a vise (wrapped) and cut the area off they recommended.
I apologize for not seeing this previously. I did install my likable kit without cutting the end pieces. I simply drilled holes where the hardware passes thru. I should add some VHB tape because the tab don’t lay perfectly flat.@yArdbird , did you install those lights without cutting the end pieces? If so, any issues and tips on how? I like the idea of no cutting.
How would you hook up this type of harness to the upfitter switch?I apologize for not seeing this previously. I did install my likable kit without cutting the end pieces. I simply drilled holes where the hardware passes thru. I should add some VHB tape because the tab don’t lay perfectly flat.
Did you have to add washers between the end caps and bumper for a solid mount.I apologize for not seeing this previously. I did install my likable kit without cutting the end pieces. I simply drilled holes where the hardware passes thru. I should add some VHB tape because the tab don’t lay perfectly flat.
There should be two wires coming off the lights, one black and one white. White goes to the upfitter wire of your choosing and black to ground. You’ll need a ring terminal for ground and a butt connector for the upfitter.How would you hook up this type of harness to the upfitter switch? View attachment 154004
I used the hardware provided. Without tearing into it, seem to recall it was the bolt, two washers, and a nut.Did you have to add washers between the end caps and bumper for a solid mount.
It looks good. I was just wondering (probably over thinking it) if there was space between the plastic end caps and the bumper. The lights just arrived today so I haven't removed anything yet.Thanks.I used the hardware provided. Without tearing into it, seem to recall it was the bolt, two washers, and a nut.
You’re over thinking itIt looks good. I was just wondering (probably over thinking it) if there was space between the plastic end caps and the bumper. The lights just arrived today so I haven't removed anything yet.Thanks.
