7.3 Gasser cutting out / Check Engine Light
I bought the extended warranty with my pickup and have wondered if i shouldnt preemptively change these to avoid the problems but have wondered if they'd be covered by the ext warranty.
Sorry to hear that but i appreciate you sharing this info.
check your warranty
mine doesn't cover plugs or wires
hope yours does🤞🤞🤞
Yep. They just called. New plugs new wires. With labor it's over a grand. What in the actual hell?!?!
I paid about $160 for a full set of Ford D wires (Rock Auto). Quick look up shows the full set of OEM plugs can be purchased for under $60. I need to start doing this job as a side hustle, almost $800 labor to swap plugs and wires sounds insane.
I mean, if it's not under warranty, do it yourself. Or, I would just go to the neighborhood mechanic (if you know and trust them)😉
Assuming you can do it yourself tell them to pound sand.
I lost a plug wire a couple weeks ago towing, swung into a dealer and had them swap it under warranty. They used the -D part number which doesn't look like the RV version that is -C. Napa carries a Belden set (699030) that looks like the -C version of our plug wires and has a fiberglass hose heat shield on them too. After the trip I went ahead and grabbed a set of those (~$70 total) and swapped them in proactively (10-20min job). I'll keep my original wires in the truck incase there is an issue but others have reported the Belden ones have been working. No idea if the -C or -D are better for our uses, the fact the RV's were (are?) getting the -C makes me want those since I tow often.
Ouch.
Same thing happened to me. Spent 150$ on wires and back to goin braaaaap!
I've had mis-fires on cylinders 1 and 2, three finally went two days ago while towing. Cylinder two misfired about two months ago while towing as well. I was close to a dealership the other day with trailer attached, so I was able to pull in for them to diagnose. They got me in for the fix right then, told me the plug wire was off cylinder 3 which caused the misfire, but replaced the plug wire since it was damaged. Not sure how a plug wire just falls off, I think all the service departments are full of it when it comes to the issue. Service guy told me I have to be careful towing since it's real easy to hook up more than the truck is rated for. Told him the trailer I was towing was 5K lbs, 3/4 ton shouldn't have any problem towing and not even close to max tow. First two repairs were covered under bumper to bumper warranty but had to pay for this one. Clearly Ford knows there's a issue, and service centers just make it up as they go. So all that being said, anyone have suggestions for good replacement wires?
Yep, misfire. Just went through this with my dealership last week. Wanted $700+ to change wires and plugs. I protested and learned a little about emissions warranties. After protesting, the service manager said the wires were covered under Ford's 8 year/ 80,000 mile emissions warranties and ONLY charged me $300 to change the plugs. I have 79k miles on my truck.
After reading the warranty, turns out that spark plugs are also covered under that warranty so I was like WTF? Reading a little further I discovered that on our heavy duty trucks the warranty is only 2 years/ 24k miles. The manager had misspoke because he didn't know all the details of the warranty. Neither the plugs nor the wires should have been covered. To their credit, he honored what he told me and I got new plugs and wires for $300.
F150, 250, 350 is light duty
F450, 550 is medium duty etc
In this instance "Heavy Duty" refers to anything over 8500lb GVWR:
It would appear our trucks are 5/50k for all emissions components. Certain parts are covered out to 8/80k only for "Light Duty" vehicles (up to 8500lbs GVWR).
  • Like
Reactions: MVI
That was my understanding after all the reading I did on the subject.
My truck only has 29K miles, I didn't know there was an emissions warranty. I'm calling Ford customer service today, I'll see if that gets me anywhere. Hopefully I'll get my money back from last weeks repair. I ordered a set of Motocraft "D" wires, fingers crossed I don't have to deal with this again. Sucks being stranded in the mountains.
