37 inch spare fits in spare location on 23+
lol maybe in 4 years when my tires wear out if they do. I've had great luck for some reason with my oversized tires. Got all the warranty mileage out of my KM3's. I think the proper inflation versus the sticker is the key honestly. but yeah I would totally do 38's and 17's.
They look so damn good
View attachment 280457View attachment 280459View attachment 280458
Although if I wasn't a puss I'd do 40's and an in bed spare
View attachment 280460View attachment 280461
and I was even less of a puss....
View attachment 280462View attachment 280463
3 mpg on that last truck when loaded
8 if it's diesel... 😜
Just get one of these.... 😉😎
What pic do you need? 25 450. Or you can order off my vin.
@NEOHIO yes please, that would settle it. Your '25 F-450 should have the 3" receiver (correct me if I'm wrong). Could you run your VIN or DM it to me for the rear trailer hitch assembly part number (17D826)? I'm trying to confirm whether it's PC3Z-17D826-C. And if you get a chance, a shot from underneath showing the crossmember between the frame rails, where the spare winch and pucks mount would clear some stuff up. Thanks!
My 2027 F350 SRW 7.3L GAS does not have the 4 circled "pads" shown in the below photo (credit to @Alpoba for the photo, as posted earlier in this thread).
I'm not sure if the pads are missing because:
a) 7.3L trucks don't have them for some reason (the diesels I've looked at have them)
b) the pads were deleted because I ordered my truck with "SPARE TIRE/WHEEL DELETE"
If these pads ARE needed for to mount 37" spare (or any spare) on the gasser, can anyone provide a Ford part #, so that I can order?
Thanks!
Thanks!View attachment 280487
I’m pretty sure it’s B. These pads are needed to sit/balance the tire rubber properly.
I’m not sure if it was you, but someone asked for the part numbers for these pads in the last few months, i remember seeing the post. Need to search for it.
Ford part
LC3Z-1A375-B is a genuine OEM Spare Tire Hoist Spacer designed for 2023–2026 Ford Super Duty trucks (including F-250 and F-350 models). It typically sells new for around $26 to $32 (MSRP around $39.60)
1FT8W4DM9SEC08339
Yes, 3" hitch
Will try and get pics. Do I need to drop the spare?
I've a 37 X 11.5 X 17 Nitto Recon Grappler on a 17 X 8.5" wide Vision cast wheel... I just aired that fifth tire/wheel assembly down to 15 psi and will attempt to winch it into position tomorrow before lunchtime.
I will report back.
It's tight, but it's up and touching all four spacer pads.
Rear pads
Forward pads
Diff
Hitch receiver
Driver side
Passenger side - need to bap that there treadblock w/ a bludgeon to get 'er tucked in there
Exhaust - need to wrap that before I might travel any distance or I gotta drop the spare until I git me some wrapp.
I'll feel better once I get this material around a 9" span* of that tailpipe.
The sheet of reinforced 1/8" X 9" X 12" will be secured w/ some stainless zip tie-type strap. The 3.5" stainless tubing's outside circumference is about 11".
*Or...
I could cover a longer span of hot exhaust tubing by slicing the silicone sheet down the middle, one direction OR the other... cover just half the circumference of the exhaust tubing but span double the distance of 9" or 12" for an 18" length or 24" length...
*ponders*
You’re getting a near identical silicone mat that i got a few years ago (black to hide it), only i feel better wrapping it against the tire vs the pipe itself. I put 2 on top of each other. It’s bulletproof in insulating from heat.
That's another way of doing it! (y)
My problem is I think I can get a more-tidy lookin' job on the pipe than on my tire. I'm a little screwy that way. Sheet's gotta be as nice as I can make it look.
Do you know how hot that part of the exhaust pipe gets? I’m sure it cools quickly over distance, but that section isn’t very far from the DPF which reaches temperatures north of 1200 degrees. Does it cool enough? If not, that would make a nasty mess.
^ ^ ^ yeah, once I took a deeper dive...
I grabbed it as a stop gap until I could find some higher-heat-capable material. Turns out I can get some Thermo-Tec non-adhesive material w/ a much higher heat rating. I have the stainless band clamps now.
I'm sure this will wind up being another area of ongoing development. :ROFLMAO:
I have over 20K on my silicone mat which is technically touching the pipe from day one. At least 50 regens later no mess, no visible damage at all, it is holding up perfectly, and so is my tire of course.
Someone posted this previously, but here it is again. It won't fully wrap the pipe, but has much better heat resistance.
