37 inch spare fits in spare location on 23+
Step #1 -- I got my 23+ hitch installed on my 2020 truck. So, THE HITCH FITS. Now I just need to find some time to pull a tire off and put it in the spare location and see if it fits. If this works, I'm dubbing this the "Participation Trophy Hitch" 😆 I have Toyo AT3 37x12.5R17s.
@dpspeed nice, glad the hitch bolted up. Following this one closely - really curious how the spare fits once you get a tire up there.
Question for the group while we wait: has anyone tried the 2023+ 3" factory hitch instead of the 2.5"? Per Ford's 2023 towing guide, only the F-350 DRW Crew Cab 6.7 HO (4.10 gears from 2024 on) and the F-450 Crew Cab got the 3". Everything else 2023+ got 2.5".
I'm on a 2021 F-350 SRW 6.7 crew long bed with the factory 3" receiver and a 3" Weigh Safe, so I'd rather stay 3" if I can.
A few things I can't nail down:
1. Part number for the 2023+ 3" hitch. PC3Z-17D826-A shows up as "with class III, with heavy duty." PC3Z-17D826-C is listed as "without class III, without heavy duty" and costs about $500-900 more. Anyone know if -C is the 3" one, or the Tremor hitch, or something else?
2. Does the DRW/F-450 3" hitch bolt onto a 17-22 SRW frame the same way the 2.5" does?
3. Is the 3" crossmember shaped like the 23+ 2.5" where the spare pucks mount, or is it the old boxed style that blocks a 37?
If anyone has a 23+ dually or F-450 and can snap a pic of the hitch from underneath, that'd answer most of it. Thanks!
What pic do you need? 25 450. Or you can order off my vin.
there’s definitly a difference on some of the hitches. I ordered a Curt class V 3” to see if I could squeeze a 37” under and it has these two tabs at the end. I plasma’s them off but before I did I emailed Curt about the discrepancy since it said it would fit my truck. Turns out the cab and chassis have different hitches. My thoughts are the tabs contributed to the capacity rating.
When i created this thread, it was to confirm Toyo AT3 37/12.50/18, on stock tremor 8 inch rim, fitting in the carrier.
I can now confirm that a brand new Falken Wildpeak AT4W 37/12.50/18 also fits the carrier easily going in on the first try inflated at 45PSI.
Interesting. Mine was pushing on the exhaust and rear differential.
They all slightly push on the exhaust, that’s not an issue as long as you add heat insulation in between the rubber and the metal. Rear diff, that’s odd, i have a good inch plus of room in between them. Was yours on oem rim too?
Nah it’s on a method 18x9. I couldn’t get the tire to winch all the way up with no air in it even. My goal was stock wheels but they rubbed hard on the stockers so that’s when I ended up with the methods
