2027 Banks Power Exhaust?
toadster
Tremor Fanatic
Folsom, CA
First Responder
Police
2027 F-350 Tremor PlatyPlus
2023 Ford Explorer ST
i jumped on their recent sale and got the Banks Intake, Hot/Cold charge pipes (HO), and the Banks Monster Exhaust
But now I see the below review:
Very nice exhaust system. Easy installation. Banks does not have updated 2027 Ford exhaust out yet so I had to modify the over-axel elbow to add in a secondary sensor bung to properly work on my 6.7 power stroke, this is entirely my fault due to I originally purchased this exhaust for a 2026 however I ended up with a 2027 power stroke instead. The legit only issue I had was one of the 3 provided stainless steel exhaust clamps would not tighten/clamp hard enough to prevent the exhaust slip connection from being loose/wiggle and probably leak, so I sourced a new clamp. Overall, I recommend Banks products, I got a killer deal during a sale even with the $55 added cost to add a bung and source a new clamp, still came out really well.
anyone here with this same experience? the slip connections maybe an install issue, but the extra bung thing is more what I'm questioning....
My 2024 HO has the bung for the sensor in exactly the area being described. I have not seen a 27 and haven't read any of the workshop manuals in PTS for them yet. I will log into PTS tonight and see if there are in fact any changes to the exhaust from the DPF back. However, if you can, take a couple pictures of your rig from that area and I can tell you if it matches what I have. I know the 23-26 were the same but maybe due to the emissions requirements that took effect for 2027, they changed something.
As far as clamp slip, a 5" guillotine clamp will fix that with no issues and can be ordered off Amazon for less than $10 or gotten from many hardware stores. It isn't uncommon for the band clamps to exhibit that. I would imagine that the post that you referenced probably had the band clamp a bit too far back and not fully over the serrations which wouldn't allow the grip. Generally, the band clamp only needs to be about 3/8" to 1/4" from the opening. Beyond that, the difference in the metals from the clamps and even the tubes themselves will incur some galvanic corrosion after a few weeks hastened by the DEF/NOx creating water. Once that happens, the joint is pretty much sealed up.
If you go the guillotine clamp route, just turn it so the nuts are on the top. That will hide the guillotine portion and give a cleaner look.
Looks like 2 bungs on the 27
Buy the band style clamps for the correct size piping. MUCH better design.
:cool: :cool: 🇺🇲 🇺🇲 🇺🇲 🇺🇲
yeah, i'm contemplating returning it when it shows up or adding a 2nd bung... I'm sure there's some OBDII BS built in here... maybe like the Chevy/Ram trucks where they'll have to provide a modified sensor to have it not throw codes...
Wow, I am a little surprised, they did change it and added a second sensor. Gotta love it. I'll for sure have to go read up on it now.
At any rate, adding a second bung to it is very easy if you have a welder or take it to an auto shop. I can't imagine they would charge much. Heck, if you were a tad closer, I'd pop one on for you.
Like what @HeavyAssault said, the band clamps are much better for sure, and I didn't even stop to think that the ones mentioned in the post could have been the wrong size. Although, I have used the guillotine clamps a few times to cinch down a joint where I stripped out the nut on a band clamp. But like I wrote earlier, I wouldn't be surprised if the reviewer had the band clamp a tad too far back. If that is the case, it would be very unlikely to tighten enough to cause flanges created by the relief slots at the opening to grip; there should be a small portion of the relief slots visible behind the band clamp, not much is needed, only about 1/8", but that is what will allow the clamp to cinch the flanges around the inserted portion for a proper grip and seal. As the pipe heats up from exhaust and then cools it will seal.
yeah, i may see if i do the bung or not, depends on the 'twist' to get things to fit on the Tremor as I think you have to wiggle the spare tire as far away as possible not to hit the 5" exhaust
Good point on the spare tire. Looking at it, I would think you could put the second bung rotated a bit counter-clockwise (towards the passenger side) from the one already on it to move it away from the tire. So long as it is properly in front of or behind, depending on how you are viewing, that should be all that matters and not the clock position you place on the pipe.
Even on 23-26 they say you have to modify the tire mounting to make it fit on a tremor… someone has to have this setup on here - right?
I have the Banks Monster Exhaust on my 26 HO same as I had on my 24 and 25. My installer had no issues and didn’t mention any modifications to get it to fit. I also have the Carli Trophy hitch and my 37 RT Pro spare is a small gap away from the exhaust. Same hitch on last 2 trucks and never an issue even with only the factory heat shield in place.
I need to call him tomorrow on some GX stuff, I will ask if he had to modify it any.
Yeah the the instructions on the banks website says have to modify the tire thingy, but a professional installer is probably gonna know what to do to begin with lol
I have the Banks Trophy exhaust with a Carli Hitch and a 38” spare. It did fit, but I didn’t like the placement or how close everything was. To fix this, I cut the hangers off, clocked both pieces of the exhaust to where I wanted, and welded the brackets back on to hold the new position. I now have better clearance from everything (spare tire and airbags) and I was able to tuck the exhaust tip up much closer to the body. This keeps it out of the way as much as possible when I am off road.
@toadster, ☝️ this is the proper way. Bo knows!
If you love your truck, you will keep it for years. Don't spend the time, money, and energy on it just to get another one the following year. Enjoy it, take it off-road once in a while, and, if you can, attend one of the meetups. There's nothing better than meeting fellow Tremorites and seeing their trucks!
For me, I try to make sure the slip fit connections are as FAR into the sections as possible. Then snug the clamps, make sure it all fits where it needs to be, then it's tightened to make sure it's done.
of course, i get the new truck with more nannies...
Starting 2027, EPA rules tighten NOx limits (down to 0.035 g/hp-hr from the prior 0.2 g/hp-hr standard). This requires more precise aftertreatment control and on-board monitoring (OBM) of the DOC/DPF/SCR system, DEF dosing, conversion efficiency, and related parameters such as ammonia slip.
The bungs include particulate/soot sensors and downstream NOx sensors. The sensors must stay installed and functional for the emissions system and OBD to work correctly—removing or deleting them will typically trigger codes and can lead to derates or limp mode.
ugh... I'll talk with Banks about timelines or whether or not I could modify.... the last thing I want is trouble codes on a new truck
I have the Banks Monster on my 24 and didn't have to modify anything so you are good as far as that goes. The only mod you'd have to do is the bung which shouldn't be a huge deal. So long as the sensors are properly upstream/downstream (depending on which sensor) is all that matters so the computer can get the proper read for calculations. I went out and looked at mine and you should have a good 20 degrees of clock position to play with. Looking at my sensor and facing the rear of the vehicle, 10 degrees counter would get the sensor completely out of the way along with not using any extra sensor wire slack.
@toadster , just make sure the first section, the one that actually bolts to the DPF, that you have to trim is cut about 1.5" to 2" longer than you measure. That is the one oops I learned from the first one I did on my 2017 to the ones I did on my 21 and 24. The hangars are plenty long enough to allow for this and it will ensure a fit like what @HeavyAssault describes.
The Carley hitch negates this problem.
