2021 Transmission Heat Shield
So I had a rattle also, I had a corn stalk do some damage to my heat shield, I used a set of toil bowl bolt washers which are oval shaped, it worked perfectly.
I ran over a yard light and that poked it and half was hanging down. The part was ripped but I can't find the part number anywher, has anyone found an answer to his original question; what is the part number?
I will need to give this a try. The larger washers I used have now given way to a rattle and when Ford looked at it, they heard the rattle but nothing was wrong...
So to replace is it just nuts holding it on posts?? My driver side was completely detached.
I wonder if putting some heat resistant tape or some kind of gasket sealer around the holes would help prevent the shearing?
Had the same issue as everyone else. Have a replacement on the way. Probably will get a few washers to help.
I just took mine off entirely. Way too flimsy and rattley.
Original transmission didn't have it, but they found the heat would warp the plastic pan. The tin foil shield was Ford's half-ass answer on newer models. I thought about removing it as well, but was concerned that if pan warps, they will deny warranty.
I was thinking about putting heat protecting wrap on my exhaust and removing the flimsy heat shield, anyone else tried that?
Mine was ripped when I hit a puddle of standing water. I've done the washer thing to put it back on, but has started rattling again.
I've been running mine without the heat shields for 3 or so years now.
dealership never recommended replacement even during warranty extension inspections. I've never experienced transmission fluid heating up & put on a skip plate 6 months ago with no noticeable increases.
have the stuff to wrap the exhaust but didn't bother because of no increases in running temps.
also
the tranny pan i busted last year. there was no heat deformation. it ran 3 years with no heat shield.
transmission warranty rebuild at 90k miles. they didn't replace the heat shield then either.
ain't messin with the pos
that's my experience anyway
