10lb Fire Extinguisher
Most extinguishers are rated at 120F for "safe operation". I haven't found a spec on maximum heat before ignition but have never seen one or heard of one going off due to heat in the car. Maybe one of the firefighters here would know? Gonna have to research this for my own peace of mind.
I'm curious as I used to carry one in Alaska but now being in west Texas, 120 degree days are common and that's before you add in my black truck and black leather 😀
Definitely a question I've always had in mind. Once it gets over 100°, I take out the extinguisher. No scientific reason; I just feel better.
100 external temp I assume? I think at 85 external, my internal temps exceed 100 in the sun.
Yes, external. It can get 122° in Vegas which means it's probably 140° inside a vehicle.
Follow-Up on this article: After searching the Amerex site and some sleuthing, here's what I found.
There are several factors that need to be considered to determine a "safe" storage of the extinguisher. Here's the short version based on the Amerex model B417 2.5 lb. dry chemical ABC:
1. Bottle construction: The bottle will have a "tested" pressure and date usually stamped on the bottom of the bottle. Mine is 40 BAR or approximately 580 PSI. Some extinguishers will also have the weight of the bottle and total weight of the chemical + bottle on a label.
2. The ABC dry chemical (perhaps others) operate at 240 PSI. (DOT specification) This pressure would have to rise well above the 580 PSI to be considered dangerous of explosion. The gauge has a max marking of 400 PSI. If the pressure was to rise past this indicator, it could be considered "dangerous".
3. Another thing to consider is the type of nozzle. Plastic may not be as robust as an all-metal version. (The Amerex B417 is all metal (aluminum) except the gauge)
4. The chemical "thermal decomposition" is 100-120 C. (212-248F) This is the point where the chemical compound can change and jeopardies its effectiveness. The chemical is not dangerous as to explosion. (Might make a mess if it goes off though.)
5. The Amerex MSDS (safety data sheet) indicates storage as: Storage P410+403 *- Protect from sunlight. Store in well-ventilated place. *if under pressure.
6. This bottle meets DOT criteria tested to 585 PSI.
7. Use valid for -65 to 120F. (Use does not indicate the pressure it will withstand but the "tested to" 585 PSI should be a clue.)
8. Kidde has a different way to specify this:
What Temperature Can You Store a Fire Extinguisher?​
Kidde fire extinguishers should be stored in temperatures ranging from -40 degrees to 120 degrees Fahrenheit. Fire extinguishers stored below -40 degrees Fahrenheit may result in the extinguisher's valve or hose cracking. At temperatures above 120 degrees, the fire extinguisher will still function, but the discharge time may be a little shorter than the 9 to 10 seconds required by Underwriters Laboratories UL.
So bottom line, you should have no problems in most all circumstances with the extinguisher stored in your vehicle. Just keep an eye on the gauge in extreme temperatures exceeding 120F.
Very good, thank you. I can now sleep knowing that my 10 oz'er will be just fine 😁.
Our favorite place to boat is Lake Mead, I have had several different brands of fire extinguishers in the cab of several different trucks over the years. And come back to the truck at the end of the day and the cab be well over 120 degrees, especially when the ambient temp is 120. It’s been so hot it has melted plastic window cleaner bottles. To be honest it never crossed my mind I could have a problem. So far so good and ceramic tint sure has helped out.
are they any pros vs cons on the Element brand (E100) Fire Extinguisher ?
several folks here have them mounted under the driver seat with a Desert Does It bracket
I carry a 10 lber, but I’ve got a camper top. Fits nicely where it’s at.
I like the set up, but probably not a good idea to have it stored next to a propane cylinder. Unless you have a 2nd/back up extinguisher inside the cab.
Well in my 29 years I have never had/heard/seen an extinguisher discharging from heat while being stored inside of a vehicle.
***Now on that note, don’t leave soda or energy drinks inside your vehicle, I have seen people do that*** 🤯🤯
I have always kept one or two in my vehicles, and that’s in the Sacramento heat (not as hot as Phoenix or Vegas) but it gets well over *110 here.
But that’s not saying it can’t/won’t happen. 🤪
I have always carried fire extinguishers in all my vehicles for the last 50 years, ever since my 67 Cougar caught on fire. (Didn't have one, someone else did, and handed it to me, only thing that saved it. Electrical short.) They are good to have in most emergencies.
However, something to remember, if you're helping someone else, with today's hybrids, a fire extinguisher may not be effective depending on what's on fire, and only good for a quick resource to help remove a person or pet. Past that, the vehicle will keep on burning, pretty much uncontrollable. My wife asked the other day what kind of extinguisher is good for an electric vehicle, I said none. If it starts to burn get out and away. (She has a hybrid BMW)
Working in the marine electronics industry and installing more and more advanced lithium battery chemistries each year, a product I found fairly recently (pretty new to market) at a trade show is a Lithium extinguisher by a company called LiCell. Expensive little bastard, but could very well save a life with the new battery technologies being implemented in marine and automotive. It's supposed to cool down batteries during thermal runaway in addition to smothering the fire to prevent the fire from growing.
Any links?
They make multiple sizes from small units similar to the Element extinguisher, to several full size extinguishers.
Thanks for the link, I've not heard of this type of extinguisher, it's very interesting technology. Looks to be an improvement for the type A extinguishers as well.
However, my biggest takeaway on the link was the you tube videos that followed their video. Some real (and unexpected) eye openers when it comes to Li-ion battery fires.
Apparently, this technology has been around for at least three years, and it seems that no fire prevention institution has endorsed it or any other extinguisher thus far as the go-to choice for fighting lithium-ion fires in a vehicle. (According to one video put on by a London professor a little over one year ago.) It seems that it's a good idea, but with the construction of today's vehicles and devices, it's impossible to get to the cells themselves and stop the burning. The best analogy I heard was it's like trying to put out a bathroom fire by spraying water on your house.
The biggest danger of the lithium-ion cell going bad is the cloud of gasses that are created and appearing as smoke. They are toxic and volatile and can explode violently under some conditions. Also, lithium creates its own oxygen while burning so it really can't be smothered.
Still, this is some cool technology and hopefully someday can be incorporated into the cells themselves to prevent thermal runaway. Until then, I will take their final advice at the end of this video (link below); if a lithium cell or EV is "smoking" run away fast.
(You can skip through the commercial by clicking on the progress line, take some suggestions with a grain of salt...)
If the propane ignites then it’s too late for an extinguisher anyways. Where it’s at it can be accessed from side door, rear door, or inside the camper easily. There’s a small 2.5 lb extinguisher in the truck as well,
Great tips here - thank you for sharing.
My wife (RN) was traveling on Interstate 91 and encountered a vehicle on fire on her way to work. She stopped and it was a large SUV that went off into the median striking rocks and catching on fire.
She (and others who stopped) were able to remove the elder woman from the passenger side (who was suffering from a broken leg) as fire spreading quickly. The woman's husband was pinned between the steering wheel and the seat. They attempted to extract him, but the vehicle quickly became overcome by flames, and the husband told the team to be with his wife and save themselves. They all sat in the grass helplessly watching as he lost his life.
She's haunted by this. First responders did make it to the SUV, but by the time they did it was too late. My wife visited the woman who was brought to the hospital where she worked, and the woman wanted nothing more than to have burned along side her husband.
I don't know if we will run into anything like that again, but we are ready for it. She's stopped at two other incidents - both patients died as she was waiting for EMS. One was a rollover as a result of a medical incident - Small compact truck. The other was a rollover in the snow and crushed in the cab of a 1/2 ton truck. My wife is an OR RN, and I am convinced she's a bit of an angel by being with these individuals as they move on.
Horrible! The advent of EVs and hybrids has made this situation worse, unfortunately. Recently near our house there was a head-on collision between an traditional SUV (wrong way driver on a highway on ramp) and a Tesla. First responders arrived and couldn't get the Tesla doors open to rescue the driver. Compounding the situation, it subsequently caught on fire and burned so hot, so quickly their EV battery fire blanket did nothing to suppress the flames. Unfortunately the driver was not able to be saved in time.
A bit of a tangent from fire extinguisher discussion but it is relevant in the sense that you need to know when it is appropriate and realistic to use one.
Your girls say it’s more like a 5 oz’er….😂
