Well the December Group buy has me contemplating re-configuring my Fire extinguisher situation. I'm going to park a small purple K on the front seat then debating what to do with the regular ABC in the bed - right now with my rolling Ford tonneau cover and Built right rails I have a 3A40BC 5lb extinguisher mounted in the rear on the driver side (right by the light button). I've debated upsizing that to a 10lb - but boy oh boy, it will be tight on height. I think it'll fit right under the cover. Its one of those "IF I need it" sort of things - I've had to use one (smaller) once before and was rapidly made aware how finite they are. Anyone rocking a 10lb extinguisher in the bed?
Purple K is great on class B and C fires and generally a small extinguisher will do in most situations. Not good for class A and should not be used in conjunction with ABC extinguishers.
I use three 2.5lb ABC extinguishers in my truck. Mainly for quick access in various situations and typically when someone else's vehicle or property is on fire. One in the bed, one behind the passenger rear seat, (tire jack removed) and one will be in the front, drivers' side mounted with the December buy. (Will create my own mount attachment.)
There's a thought pattern here that if I am faced with an emergency vehicle fire, it will likely be a class B. One 2.5 lb. extinguisher (10BC) will likely put it out. In the event where multiple extinguishers are needed, it's relatively easy to grab a second or even a third. Now if it's a case where
my truck is on fire, AND it is a large class A, an extinguisher will likely not work because of the complex structure of everything that could catch on fire and inability to "smother" it. Also, consider location of the mounted fire extinguisher, if reachable. Every fire needs a quick evaluation as to how to fight it and sometimes, a decision has to be made to fight or flight. In a situation where you have a major fire in the cab, you're better off closing the doors, walk away, and hope it runs out of oxygen. Let insurance do the rest.
A class C fire will continue burning until the source is removed. (Electrical short.) Otherwise, it would be considered a class A if the electricity is removed and still burning. (Or ignites fuel, in which case is class B) One 2.5 lb. extinguisher should do the job if encountered soon after the incident. The object is to fight a small fire to keep it from getting large and avoid getting burnt yourself.
I have used fire extinguishers in real life situations and know how to evaluate and fight a fire. (I am not a pro, nor would I compare myself to a pro, but had training from military firefighting schools and seminars with FD as well as dealt with real fires.) If you happen to be a firefighter, LEO, or have a background in this area, you know that most advice is to walk away to protect yourself. I would avoid trying to fight a large fire with an extinguisher unless there was possible person or pet or similar danger situations. (Starting a forest fire) A small fire is what the extinguishers are generally for. A 10 lb. or larger extinguisher in a vehicle is most likely overkill for the situation you will face, unless you can fight it from multiple directions with help from another carrying a second extinguisher. A 5 lb. should be quite adequate for most all situations encountered.
And besides, a 10 lb. is more expense and still needs to be recharged, even if used for a small fire. AND, if you do use one on someone else's vehicle, two smaller extinguishers still leave you with one if the other is used. Handy if out in the field somewhere.
And final note, if you've ever attempted to use an extinguisher and it did not work, (Oh yes this is real, happened to me once) it's nice to have a backup to get your heart pumping again. (I keep two on the boat as well.)
