Z flash wad of wires?
A device that can strobe all your light. I don't recommend it as you shouldn't be messing with the BCM and people have fried the BCM using it in the past.
Oh trust me, I get flashed way more than I've flashed this unit. It's only for entertainment purposes only 😁.
Well this is good information, I've been thinking about ordering one of these but really? That's how they expect you to tuck your BCM connector?!
Yours will be easier.
@legmar has it too but I believe his unit is the previous generation. He will help though.
I did have an issue with the one for the 22. Reverse lights stopped working and they swapped it out without any questions.
I had an issue with a ZFlash module as well… one of the connections in my first one must have been bad because my lights would flash but my windows would stop working when the ZFlash was installed. They quickly swapped me out for a second ZFlash module, and everything works great now.
Okay, now about fitment. I found (like others) that I could tuck most of the wires behind the kick panel for the fuse box and close it most of the way (friction fit close). This has worked for years with no issue even though the panel lid isn’t technically snapped all the way down. For the actual ZFlash module, I have that placed on top of the bottom panel underneath the glovebox. Here’s some photos.
This isn't the same module that I have correct?
That’s a good call out… yeah, it appears your module has an updated design. Similar though…
If I remember on your YouTube channel, your module is from a couple years ago. They just recently created a new module several months ago.
However, it's ridiculously tough to tuck it in the fuse panel.
I may have to scoop up this new module to do some research with it! 😁
I have faith that you can pound the new one into place and make an educational video for the rest of us to follow your lead.
I would suggest these.... I have their mirror spot lamp speed override - amazing and easy. Though - not cheap - these are quality. It connects to the lighting not the modules AFAIK.
I do like their flashers and I've looked at them before I bought the z flash. However z flash wins in regard to cost and ease of installation.
I agree for ease of install and cost. I have watched Arod install these from Limitless - and WOW! There is a lot going on.
I like those too... I only bought their mirror spot light strobes though since they are plug n play and used Zflash for the rest.
Ok @Optimus I figured it out. You'll have to do a little more disassembly, but once you do it's a lot easier. I took the glove box and the rest of the corner kick panel off completely. Then I could unplug the two bcm connectors below this giant one. I ran the adapter down under the bcm and that's where the big plug is now in the picture. I also had to cut one factory zip tie. And now as you can see everything fits as it should like it's factory.
View attachment 187975View attachment 187976View attachment 187977View attachment 187978
Excellent write-up my friend! I'm all wired up now! I figured something had to happen because I can't let it dangle for too long 🤪. Thank you again and hopefully I'll get this done in the next year 😁.
Somebody had already told you this i believe?
