Won't shift into 4wd / dealer issues
bb_overland
Denver
Navy
F-350 Tremor
Hey guys,
Having some issues with the drive train and also a Ford dealer. I'm not sure if this is the correct forum for this, but it seems to match. The short description is that my '22 F-350 Tremor won't shift into 4WD, and I get the error 'early shift detected'.
First some quick background information
  • Truck has a BDS 7" lift on it and Atlas rear springs
  • Front and rear drive shaft is Adams
  • Nitro 4.88 gears
  • Front electronic locker - Eaton 14022-010 Dana 60 E Locker
  • Front axles - DYNATRAC HD BALLJOINTS™ FOR MOST DANA 60 AND DYNATRAC PRO 60 KNUCKLES WITH RCV AXLESHAFTS
  • A bunch of other mods, but nothing that should affect drive train
Background story -
I worked with a local offroad shop to install all of these parts for me. I ended up experiencing an issue with the transfer case where the vehicle wouldn't go into gear after it was shifted out of 4wd. Took it to Groove Ford in Centennial (now Arapahoe Ford) to get it replaced. They would not honor the warranty as they blamed the lift, and BDS wouldn't honor the warranty because they said it was a seal failure and that should be covered under warranty. So, I got stuck with the bill.
Come to find out, the Ford dealer actually took my Adams 1410 driveshaft from the rear and replaced it with a factory part, claiming the driveshaft was damaged. There was no explanation of how it was damaged, and I didn't find out until after they completed the service that they did that. It was not in the original service description where they said they just needed to replace the transfer case. When I eventually did try and shift to 4wd, I no longer could shift to 4wd and got the "early shift detected" message. The front Adams driveshaft is still in place.
What does this error mean? Googling the issue didn't really get me anywhere. Could something have happened when the dealer worked on my truck? I'm not even sure what to do about the dealer taking my aftermarket driveshaft without permission. Are there any options with Ford corporate?
Just really not sure where to go from here. Any help is appreciated. PFA
Do you have a actual code in the tccm? Unfortunately your issue is pretty rare and there wont be a lot out there to google diagnose it. being as modified as this truck is I would start checking every connection on the transfer case. Look for pushed out wires, broken wires, bent terminals. Did this happen from the start after lift installed or did it take time to happen. Many questions need to be answered before any beneficial help can take place.
I believe that this took time to happen. It definitely worked fine after the initial lift was installed and even after I off-roaded with it. I noticed this issue after I had the t-case serviced at a ford dealer. Lift was originally installed in 2023, transfer case issue happened in '24.
I hadn't even tried to shift to 4wd for a couple of months until I got to a trail recently and it just wouldn't go.
As you can see from the wiring diagram these systems are so intertwined The issue could lie anywhere. However I would look at what was touched by humans. when you say serviced do mean a fluid change or an Issue (binding or slipping).
Sounds like several separate issues that may or may not be considered related. Obviously the shady slight of had service by your dealership is not directly a Ford Corporate issue. They could refer you to your lawyer on that part, honestly don’t know.
Having installed so many driveline aftermarket parts and BDS denying any responsibility, that leaves you back with your lawyer to try to get some traction with Ford and your dealership.
You say, “A bunch of other mods, but nothing that should affect drive train”, right after a whole list of major changes to the suspension and driveline. My gut says you have an uphill battle on your hands that will most likely involve litigation.
Edit: Not saying you don’t have a winnable case, just saying It probably won’t happen with phone calls and emails from you to the dealership or Corporate.
I will look at the wiring here in a few. Totally agree that is likely where the issue lies.
When I say serviced in this context, the entire t-case was replaced.
But why was it replaced the first time. It could be as simple as they didn't program the encoder motor, or initialize a new module on the network.
They said it was a bad seal in the transfer case. I had a catastrophic issue on the highway where it just blew.
With the BDS 7" does the transfercase get index with an index ring? or did you use an high angle driveline instead?
The transfer case gets indexed.
Given the run around (and my general dislike of dealers beginning when I grenaded the t'case on my Dodge and Lillith Dodge in Fort Collins told me to pound sand and blamed my stock! driveshaft because it had rock rash) you may be time (and even money) ahead to go to a private shop that will just fix the issue. On my Chevy I tried everything (well out of warranty) myself and I couldn't get the transfer case to not cause codes/no shift. I ended up going to this shop in Castle Rock (I think, its been awhile) and they found part of the wire harness was broken and bypassed the 4wd control for me. It worked flawlessly, didn't cost much and they didn't give me the dealer BS of "you need a whole new wire harness which will be worth more than your truck."
Just an idea, (I'm not endorsing the shop or anything, it was quite awhile ago and I believe that was all the work I had them do.)
Are sure they replaced the entire t case?..Had a similar issue and they just rebuilt the front half, where the seal left the chat.
Will it shift into 4wd drive if you are stopped? Mine did at first but it finally went completely out.
A few months after they replaced the front half my t case wouldn't shift into 4wd..the coil in the shift motor in the t case had burt up. They rebuilt the back half and its been fine for 20k miles.
I'll go back over the service notes. They're pretty vague. It doesn't shift at all.
