I dunno man, I don't believe you. I see zero reason why my windows shouldn't operate buttery smooth.Make sure to get some dry silicone spray and hit those window tracks annually. It will greatly reduce the load on the window drives.
Do you spray inside the tracks or just wipe down the edge of the windows and let it work itself into the tracks that way?Make sure to get some dry silicone spray and hit those window tracks annually. It will greatly reduce the load on the window drives.
You would be amazed at how many months some of these trucks set without being run long enough to do any real charging. Between the factory, delivery and the receiving dealership they get started repeatedly, run for less than five minutes and shut down for days or weeks. This is the perfect scenario for ruining a new battery.It has 5500 kilometers on it lol. Shouldn’t be the battery already
Open the windows and spray inside the tracks. Wipe any excess off. That’s why I like the kind with the straw attached to keep the mess to a minimum.Do you spray inside the tracks or just wipe down the edge of the windows and let it work itself into the tracks that way?
And to know this product was created ten years before windows were installed in cars, is just amazing! They were ahead of their timeOpen the windows and spray inside the tracks. Wipe any excess off. That’s why I like the kind with the straw attached to keep the mess to a minimum.
Make sure to get the drying spray to keep crud from collecting in the tracks.
If he said it, I missed it, but the engine needs to be running for this to work. At least it did on my ‘25. Just tried it since mine has been bouncing back again (weak battery).Just had this pop up on Facebook.
10K reactions · 472 shares | Fix Auto Window Issues in Five Seconds Hold the button up for five seconds after it closes. We're showing you the reset that fixes auto windows before you waste money at the dealer. Has yours done this before? #FordTruc
Fix Auto Window Issues in Five Seconds Hold the button up for five seconds after it closes. We're showing you the reset that fixes auto windows before you waste money at the dealer. Has yours done...www.facebook.com
