Wide vs Narrow Off-Road Tires
I've had 12.5" wide tires on my previous HD trucks, and was close to pulling the trigger on the same on my '22 . But have grown to love the oem size, its tall enough to fill out the wheel well, handles nicely, gets surprising mileage (19+mpg lifetime avg over the last 17k - 85% highway). For looks I could see changing wheels to push the offset/stance out a little bit.
As for traction when things get sloppy in my property, sometimes I need to pull out trailers from grass/dirt spots to the gravel drive. Best truck is the dually with skinny tires, even with mild tread! Worst was 35x12.5 ridge grapplers.
The older I have gotten the more I have found myself trending towards skinnys/pizza cutters/narrow tires. In my youth I was all about the big offset and super wide tires but I've grown tired of the look and the drawbacks of that setup.
An interesting video I just came across.
What are your preferred tire sizes on stock 18" wheels?
As @BroncOh pointed out...I merged the thread into this legacy thread to keep the discussion together. :)
Very informative. Thanks for sharing.
I concur with this, I have approximately 25K in upgrades and mods, wheels and BIG tires are not part of those upgrades! My '21 Tremor has stock black wheels, I can't count the times I almost changed. You notice i said "changed" not upgraded. I feel the OEM wheels are good looking, more importantly they are structured consistent with a heavy duty 🚚 truck. Also a black wheel is a black wheel and not noticed by anyone but myself and a limited few others IMO. I removed the OEM 285-75-18 duratracks at 35k and replaced with 295-70-18-35 Faulken AT3. The Faulkens project a more aggressive stance and tread, are quiter, and handle exponentially better. My 295x70 Faulkens are only 1/2 inch narrower than a friend's 12.50 x37 Faulkens measured mounted on the ground, on the truck (s).
I will add of the 25k in upgrades and mods that are functional the #1 upgrade i have done with the most noticeable improvement were shocks. I went with Fox reservoir, but I have been told you can achieve an equal result with Bilstein.
Remember, most all of the big off-road names (CJ, Bronco, Scout, Series 1&2 Land Rovers, etc.) all ran taller narrow tires like the STATraxion or the military's NHT tire for the longest time.
Yes. The military is concerned with performance, while the American civilian aftermarket is concerned primarily with appearance.
If you visit Africa, Australia, India, Switzerland, Germany, Norway, and other countries that don’t share America’s visual expectations, you’ll see narrower tires on everything that’s really used to transit the Alps, Serengeti, or Outback, and zero vehicles running wheel offsets or spacers that push the tires well outboard of the fender protection. The American aesthetic is mostly informed by children’s toys and mall crawlers. (Nothing wrong with that.)
I studded the stock Duratracs for winter use, but bought 37s on aftermarket wheels for the summer. I prefer the ride on 37s, and I’ve been distorted to appreciate the look of them, but the steering is harder — which is a reminder that the stresses and wear on the steering components will be greater.
Thanks! Sometimes it's hard to find things on here but glad the masters know where to look!
It's all good! We sure have a bunch of good content!
the interesting part to me is that the rubber contact patch is the same with the same tread design and different widths. This essentially means the gap between the tread is what is getting bigger on increased widths without any increased rubber, right? Is that a Mickey Thompson thing or an every brand thing? Would Toyo AT3s for example have the exact same contact patch between sizes? Also what was super strange to me was that a MT KM3 tire has bigger contact patch than a 3 peak rated AT tire.
Since many on this forum run either 35s or 37s, would be interesting to see this with a Toyo/nitto/Falken and take a true 35x12.5 and compare to a 35x11.5 (even though I know only a few brands actually do the 11.5 widths).
The video is very telling regardless and while I can totally appreciate the science behind it it’s just hard for me to comprehend how off road performance is better with less tire (save for sand as previously mentioned)
Interesting thread.
I come from the era of 7.50 16 mud grips were serious off-road tires.
At that time they were nylon tires and rough as a cob but would certainly get you where you were going no matter how rough it was.
Used them on everything from jeeps to 3/4tons.
I had a new F250 “high boy” in ‘77 with 7.50 16s. It was a badass truck…..wish I still had it!
Enough reminiscing…..carry on
I've got 9.00R-16's on my Power Wagon. 36" tall. Very serious off-road. Michelins.
Had a '70 F250 w/ a 390 and a four speed that had 7.50-16's as well, 'cept I put Michelins on it... not nylon. I was in the tire business back then so I knew my options, and went some 33x12.50x16.5's BFG's for a second set. The truck handled like a sports car and soooo fun to drive going through the gears.
I'm trying the 37's on 9" rims on this one, mainly for ride and handling and the type of dirt it will likely see, keeping the OEM rims for winter. Hoping to find taller & skinnier for the OEM rims down the road if the need comes up.
Interesting thread.
Surprised you didn't mention split rims!! All the 3/4 fords 16" were split rims, probably most on here never heard of them@!
Lol, all I can think about is the Pontiac commercials for the "wider is better" selling point. I wanted my aunt's car sooooooo bad because of it 🤣🤣🤣
