Weird question about upfitter switches
Phil314
Tremoraholic
45.2521, -93.5612
2020 F350 Tremor 7.3 Lariet BAP
94 CBR600F2 @ 232K
Just curios for those people using their upfitter switches to control a solenoid.
Did you install a flyback diode or not?
Have you had any problems?
Does the upfitter switches/relay box already have flyback protection?
I went down a rabbit hole and someone needs to save me.
Okay.....make me not feel dumb about asking what is a "flyback" diode.
Aaccording to the database:
A flyback diode, also known as a freewheeling diode, protects electronic circuits from voltage spikes when an inductive load (like a relay or motor) is switched off. When the current is abruptly stopped, the inductor's magnetic field collapses, causing a surge in voltage. The flyback diode, connected across the inductor, provides a path for this energy to flow, preventing damage to other components.
I wired my Warn winch to a Warn solenoid then connected it to an up fitter switch. I didn't put anything else in the circuit. So far, no problems, nothing has burned down, and I haven't woken up to dead batteries. My start/stop sequence is the truck(high idle if needed), then the up fitter switch, then finally run the winch. I think this would keep surges from happening? Warn wanted it directly wired in, I added the solenoid so there isn't always a ton of power pumping into the front of my truck in case I hit something really hard.
I did the same. For a circuit needing flyback protection tho the load is what would be switched on and off by the solenoid. So not the same as using the solenoid as a power disconnect for the winch, since the electrical load of the winch is controlled by it's relay box ideally you'd never be shutting off the upfitter with the winch under load.
@Phil314 to answer your question, I'm honestly not sure if there is protection in place, probably not, nor am I sure it's necessary. What are you using the solenoid to power? Maybe it's another one of those things where it's better to be safe than sorry if you want to put one in the circuit.
Thanks for clarifying with what sounds like science and education. My typical Google until I get frustrated then just do it approach is probably way less clear and is usually based on "how much does it cost to tow my truck to a repair shop" searches.
Well, I'm a little late on this one. Looks like the explanation is clear, @Optimus🤖 nailed it! So, to clarify, the diode allows a path to ground for the extreme voltage spike when an inductor collapses when power removed. Typically, it has low energy depending on the size of the relay. A large relay such as a winch drive etc., can cause a large high current spike. The drive circuit for the upfitters is a relay, not an FET. So essentially, it is not prone to the spike. And the upfitter relay driven by the BCM will undoubtedly be protected in the circuit. Still, the diode is not a bad idea with a high current load. Read on.
It does not harm anything to put the suppressor diode in the circuit of the relay coil of the external device. It hooks up reverse biased so there is no current flow until the relay is disconnected, and a spike is generated. One reason I put this diode on most any large relay is that the spike in theory can pit the relay drive contacts. (Not the upfitter relay drive contacts, the load contacts.) This protects the load drive contacts. Another method is to use a capacitor across the coil, but that is not as good in most cases as the diode.
If anyone needs a schematic, let me know.
p.s.: I do not use diodes on my light drives, the relays in the upfitter seem to handle these just fine.
ps.ps., Flyback is from an old term back when TVs used a flyback transformer to generate high voltage and horizontal drive for the old TV picture tubes. The voltage generated could exceed 20 KV.
Currently the solenoid is being used to 'activate' main power to an anderson plug at the front of my truck.
I have a winch on a receiver plugged into the front right now.
But I can also plug in an inverter if needed.
Future plans are to run an air compressor and a rear anderson plug to a DC-DC truck camper.
Switching off the solenoid will kill power to everything.
My concern is mostly for the DC-DC charger. It may not like having power suddenly cut-off. I'm researching this.
But this led me to switches/relays/flyback diodes.
As near as I can tell the upfitter switch controls a relay in the upfitter box. I'm fairly sure that it has protection since it was designed by ford for a variety of applications. I would think they'd protect that relay from both sides to protect the upfitter switch and the relay.
And since that relay is controlling a solenoid, I'm guessing that any flyback from the solenoid would be handled but the upfitter relay and no extra protection is required. Just no 100% sure.
I figure the worst that could happen is that I'll eventually fry the contacts in the upfitter relay but they are cheap and easy replace. Long story but I'm sticking to it for now.
