I used flex tape on my driver floor pan access point. Granted, the PO cut a slit in that rubber grommet to pass through a wire. So far, i have not had any issues and my truck has SAT in water deep enough to thoroughly test it
Have you checked to see if the pad is wet towards any direction? If its only wet in the middle then its obviously coming from that grommet. water typically wont travel underneath the carpet and NOT get things wet along its path.
