Water Intrusion
Here's pics I took while performing TSB 20-2170. Didn't think about taking pics until I was already into it and had RTV on my hands and didn't want to touch my phone at times, but here's what I have to share.
My truck hasn't had water intrusion, so I was just doing this for preventative sake. I did notice the foam around the drain tube was wet, and while water hasn't made its way into the cab yet, I can see how it would.
I read many discussions about this TSB and getting water into the cab due to this issue, from Tremor Forum, FTE, and a couple F150 forums. I've read accounts of guys simply having the elbow installed and still getting water into the cab thru the foam seal around the drain tube. I knew going in that I wanted to completely protect that foam seal from getting wet. I took direction from some of those discussions and "improved" upon the steps in the TSB (IMO anyway).
The TSB only shows to apply 3M 3340 foil tape over the installed elbow, seemingly to protect the elbow from heat (?) This leaves the foam seal exposed to potentially get wet and I wanted to make sure that foam seal stays dry.
Apply heat shield tape over the elbow as shown in Figure 6
The heat shield on my truck had a hole not much larger than the foam seal around the drain tube.
There's about an 1/8" gap between the heat shield and firewall on my truck and I can see how water could potentially get between the firewall and heat shield from above and run down to the foam seal, maybe when driving in a bad rain storm or something. (these two points can be seen in a later pic)
I wanted to apply foil tape directly on the firewall and cover the foam seal completely, so I cut away a section of the heat shield.
Something mentioned in several of the threads I'd read was that the drain tube has a couple ribs on the bottom of it. If you apply the elbow over these ribs, it just creates a gap in the fit of the elbow and drain tube, which can allow water to seep right back to the foam seal - the very issue the elbow is supposed to resolve. Why Ford doesn't address this in the TSB is beyond me. Like others, I used side cutters and a razor blade to trim those ribs off so the drain tube is smooth. The pic below indicates where the ribs were.
I cleaned the firewall with alcohol and applied a piece of foil tape to cover the foam seal. I cut a hole in the tape for the tube to stick thru.
On layer of foil tape may have been fine, but I tend to over think things, so I cut two more strips of foil tape and cut slots in them like below. I then installed them with the piece on top overlapping the bottom piece like shingles or siding on your house. Thinking was to ensure any water that may flow down the firewall can't get under the tape and reach the foam seal.
Bottom strip of tape installed first
Top strip of tape installed last, overlapping the first strip.
I cut a length of 3/8" fuel line about 4" long to extend the length of the elbow. Any water that drains out will exit far away from the foam seal.
I smeared RTV on the OD of the fuel line before inserting it into the elbow.
Then I smeared RTV on the OD of the drain tube and around the hole in the tape, and installed the elbow onto the drain tube.
Next I installed a strip of foil tape over the elbow, as shown in the TSB. I also added another strip of tape at the top of the elbow to create a "hood" over it, so any water that may ever flow down the firewall or heat shield will be diverted around / away from the elbow.
Last, I re-installed the section of heat shield that was cut out and taped it back into place with 3M 3381 foil tape. The 3381 tape has near the same specs as the 3340 tape, but doesn't have the red text on it and looks like all the other foil tape Ford uses in the engine bay.
I thought long and hard about using the 3381 tape on the elbow, but it does have a little lower heat resistance and strength, so I decided to go with what Ford spec'd in the TSB on those areas. If there is ever any discussion with a dealer about it, I used what Ford said to use.
You'll also see in the pic, I made sure the fuel line dumps the water straight to the ground and not on the frame rail, so there's no chance it runs down the frame and pools somewhere and results in corrosion / rust 10yr down the road.
Nice Work, I was away for work when I had the TSB performed so I wasn't able to dive into the situation. This is a great addition to the original TSB! When I get some time I'm going to take your advice and silicone the foam also. Great advice, Nice Job!
Got my drain elbow RTV'd to the fuel hose. Used Permatex 'The Right Stuff' black. Also including a photo of the Nashua tape I bought.
Tomorrow I will attempt to start working underneath the truck and trim the fins off of the drain. It's going to be close quarters. I'd like to get this TSB done tomorrow, if possible.
Just so I am clear on this, they put out a TSB in 2020 but 2022’s still have the exact same design?
Correct. Everyone should be doing this preemptively. Dealers won't because the TSB is only for certain dates of trucks :rolleyes: .
Well that’s certainly disappointing.
I just completed the drain elbow TSB. Glad that's over with. I used a bungee cord and a Milwaukee vise grip with a hole in the end and zip tied it around the rim to hold the fender liner back out of the way enough. The drain hose extension will divert water away from the electrical harness and frame.
Thats very clever idea with vise grips and ties! Nicely executed.
Looks good man. That aught to be as water tight as a frogs arse (y)
After all these rains here on the left coast. My truck windows were wet and fogged on the inside and now it smells like a wet dog. Found the passenger rear cab vent seal to be folded over. Terrible picture but I’m relatively sure this is my water intrusion.
That looks promising. There are others who have had the same trouble spot.
Do this and even if that vent separates it wont flood you no more
So is your carpet in the rear wet?
Thank you for the info... yes, air vent which made me scratch my head but then again, I'm no mechanic nor do I play one on TV. I have a 300 foot asphalt driveway and it's flat. My profile picture is how it parks in front of the house. Will be interesting to see how it goes as this is my first Ford (I graduated from Toyota Tundras to Ford F250 😀). I haven't filed an insurance claim since it's covered under warranty but might reach out to USAA and see what they suggest.
USAA takes care of their customers. Just recently did a comprehensive claim on a different vehicle and seemless evolution
Stop rain water from going down into your vents, prevent the exact issue @co425 is suspecting.
I get the purpose of the rubber between the bed and the cab stopping the water, but you are saying the rubber on top of the bed rail helps divert the rain?
