Had the same thing happen to mine. Took a few times for them to figure out one of the rear cab vents had been rushed from the factory. Mine wasn’t pouring out like this though. Just a small spot of wet carpet.
When I peeled back the passenger carpet, I noticed the seal lifted on the tunnel as well. I figured it delaminated due to being water logged, but maybe it was never sealed?I’ve dealt with water in my 2022 as well. No where near as much as you’re describing though.Dealer has spent over a month working on my truck in 3 different services. First they found missing seam sealer on the transmission tunnel, 2nd trip they couldn’t source it, and 3rd they finally found a pinched wire effecting the windshield seal. Glass company is coming Monday and we’ll see if that finally corrects it.
Pretty discouraging Ford can’t make water tight trucks. I’m loving the truck otherwise. Got an ARE canopy installed - funny thing…it’s the first canopy I’ve had that doesn’t leak.
Actually I guess they're making vodka out of the Artesian water. I saw a bottle (with the old style Olympia Label) at the Safeway last night.First, you should move out of Olympia since they don't make a decent beer there anymore, the Greeners are out of control, and you won't know how depressed you are because of the constant rain until you're measuring for the hose from the exhaust into the cab, and move to Alaska.! Where the rain is Frozen for 6 months out of the year.!
I considered asking them to do the carpet delete during the repair, but figured there is padding underneath the rubber, right? Easy way to see if you have water intrusion is to remove the plastic trim were the carpet meets the door. My body sills had standing water, both front and back.Damn seeing these water intrusion concerns makes me worried about having the carpet delete - definitely not as easy to "feel" if the floor is wet due to leaks. Damn, these leaks suck.
I pulled the carpet away from where it meets the firewall and ran the AC on max for an hour. No build-up on the inside and looked like it all drained out of the firewall tube properly. I just saw a YouTube video of the sunroof drain disconnecting near the foot well areas. I hope it's that easy.There’s a known issue with the seal around the AC box on the firewall, if you’ve got water on the passenger floorboard have them look there
Here’s the AC drain with the $6 dorman elbow from auto parts store. Hopefully this is my leak pretty sure it is but we’ll see. There’s a ridge on the bottom of the tube coming out of the firewall you want to dremel off. I also coated it with some black rtv silicone. Here is the tsb https://static.nhtsa.gov/odi/tsbs/2019/MC-10168762-0001.pdfI love this forum. I’m having same issue and tried scheduling service at my dealer but they are a month out. Will try doing the TSB elbow fix I believe that’s where mine is coming from.![]()
Glad they found the cause, hopefully you will be back as good as new soon. Let us know how the repair goes.Got an update on my leaking 2022 Tremor today. The windshield was not sealed properly on the passenger side. They ran the defroster on high and got some soapy water to bubble around the defective area. Unfortunately, the dealer sat on it for too long and the carpet will have to be replaced as well. I'm just glad they found it. They said some earlier models had a TSB for them spraying the clearcoat too far in where the sealant bead goes which would prevent a good seal. They said this wasn't the case with mine though. I never heard of running the defroster to find leaks before. I read you can also use an air gun to blow the inside edges of the windshield if you have a helper. Good to know!
Found someone with what seems to be the exact same air vent issue:Hello Family, first post for me but have learned a lot from all that you post.
Was wondering if any of you have had water intrusion issues with your Tremor? We just started having our Pacific Northwest rain for the past few weeks and I noticed that brutal smell when I opened the door. That led me to look under the WeatherTech floor mats and discovered massive amounts of water, to the tune of a half filled shop-vac. When I opened the rear door, water poured out (see video) from the carpet.
Took it to the dealer and they indicated that the air vent on the back of the cab was not sealed properly. They had to order a full cab's worth of carpet and carpet padding along with a new air vent. That will arrive next week and will take a few days to gut the cab, remove wet stuff, and replace the new. Needless to say that I'm worried of other potential issues that might come up as the truck is only 3 months old.
I've never had an issue like this so am wondering if there's other things I should be on the lookout for or if I'm freaking out for no major reason.
Thanks again for how much you all help us Tremor Rookies!![]()
Super sorry to hear that you're going through the issue I had last year.I noticed a musty smell in truck a few days ago and we had some really humid spring weather so I had not thought too much about it. Then yesterday seemed stronger and the weather has turned cooler. I have WeatherTech HP mats and checked under them to feel damp carpet. It was slightly damp in the rear and more wet in the front both on driver's side. Bottom of the front mat had condensation on it and I popped the door trim plate and checked underneath to find wet jute under the carpet.
I had a leak from clogged sunroof drain on 2014 F150 but that leaked into headliner and was several years after I got the vehicle. This truck was built in November 2021 so should not have had any time for anything to build up to clog the moonroof drains. Just to be certain I poured a few ounces of water into both moonroof corners and water immediately came from fenders onto the ground so no issue there.
I headed to the trusty forum and found this thread. The cab vent felt like the most likely to me and I used the hose to run water behind the cab and there it was, immediately wet carpet by the amp and then into the door channel running with the rake of the vehicle to the driver's foot well where if carpet was in place it would have been soaked up into carpet and jute.
Looks like driver's side cab vent is the culprit. The question I have is whether the dealer can properly replace the vent without moving the bed back? I have the factory spray in bed liner and if they have to move the bed they will have to breakthrough the bed liner to take out the bed bolts.
@4DFALLEN have they finished the work on your truck? It sounds like I have the same issue they discovered on yours.
Super sorry to hear that you're going through the same issue I had. The vents were the issue as they weren't properly installed. My dealership has a 3rd party vendor come in to do leak repairs but it was covered under warranty as well as the rental car they provided me. I also have the spray in liner but the repair guy did not have to break through it to repair the vents.I noticed a musty smell in truck a few days ago and we had some really humid spring weather so I had not thought too much about it. Then yesterday seemed stronger and the weather has turned cooler. I have WeatherTech HP mats and checked under them to feel damp carpet. It was slightly damp in the rear and more wet in the front both on driver's side. Bottom of the front mat had condensation on it and I popped the door trim plate and checked underneath to find wet jute under the carpet.
I reached out to 3 dealers earliest available appointment was 4/26. That is nearly a month of leaking every time it rains and we get a good bit this time of year in NC. This baby don't fit in the garage so time to take matters into my own hands.Super sorry to hear that you're going through the issue I had last year.
Make sure they tear all the wet stuff out and let it dry for a few days prior to having them put new stuff in. That's what I demanded and haven't had any issues since.
Good luck and let me know if you have any other questions!
@4DFALLEN and @Red Forman have they finished the work on your trucks? It sounds like I have the same issue they discovered on yours
Nicely done!! Reading through this thread has got me thinking of checking this soon before spring showers start here too.I reached out to 3 dealers earliest available appointment was 4/26. That is nearly a month of leaking every time it rains and we get a good bit this time of year in NC. This baby don't fit in the garage so time to take matters into my own hands.
I grabbed my inspection scope to get a good look between the bed and the cab and it looked like the vent on the driver side was out farther at the top than the passenger side one. I got a paint stir stick and could press against the top of the vent and it had movement.
I then took the amp and sub out and the rear wall material and could see that the vent was not clipped in on the top. I am not sure if this is from assembly or if it happened due to a faulty part or design. I could clip the vent in place but the driver side one seemed to be looser in the hole than the passenger side. I could work the vent up and down and it seemed like the tabs might drop off the edge again.
I noticed the gap from below the securing tab to the surround appeared to be about the same thickness as my trusty stir stick. I cut a couple safety spacers from the sacrificial stir stick to insert in the tab slot and whalla fancy interior on a 78K truck saved by a freaking stir stick, a small piece of electrical tape over the "spacer" and now everything was sturdy as could be.
Before putting everything back together I sprayed the back of the cab again and all good nothing coming in. You can actually see pollen from our wonderful NC spring on the right side of the vent in the videos and photo attached. Drying out the inside now and hopefully no more issues.
View attachment 49717View attachment 49730
Probably not a bad idea as it did really seem like it could work itself loose before i braced the upper tabs. I have a flush trifold bed cover and that likely made it worse since it funnels more water into the rear of the cab. You can get to the vent between the bed and the cab to see if they are secure without taking out any of the interior. I feel like mine may have worked loose as I have not noticed anything until recently and I took delivery in first of December 2021.Nicely done!! Reading through this thread has got me thinking of checking this soon before spring showers start here too.
Thanks! Great info... I will be checking mine for sure - looks like a great preventative action to take regardless.2022 Tremor 10,000 miles. Just found a water intrusion on front passenger floorboard. Was smelling a foul oder and after looking around that is when I found the damp / wet carpet floorboard. Originally thought it might have been the sunroof drains but they are clear. Blew them out with compressed air and confirmed that water was draining properly. After further research I found a (TSB 20 -2170 F150 / Super Duty Passenger Floor Wet When A/C Is On). Even though this TSB only refers to 2018 - 2020 I looked at my 2022 and it has the same issue.. All the Ford dealers are booked out until August and since I need this truck I'll be taking matters into my own hands and the dealer and I will catch up in August about replacing some carpet. I do believe this is where the water was coming from since there are no traces of water except where this A/C drain tube exists the firewall. I highly recommend you all fix this issue on your trucks before you get water on your floor too! Attached is a video of the TSB and a link from Amazon to purchase the rubber elbow to fix this issue.
