Water Intrusion
Just an update, I preformed the fix in regards to the water leak TSB 20 2170 and it has fixed the water leak on the floorboard. So far so good.
Here's pics I took while performing TSB 20-2170. Didn't think about taking pics until I was already into it and had RTV on my hands and didn't want to touch my phone at times, but here's what I have to share.
My truck hasn't had water intrusion, so I was just doing this for preventative sake. I did notice the foam around the drain tube was wet, and while water hasn't made its way into the cab yet, I can see how it would.
I read many discussions about this TSB and getting water into the cab due to this issue, from Tremor Forum, FTE, and a couple F150 forums. I've read accounts of guys simply having the elbow installed and still getting water into the cab thru the foam seal around the drain tube. I knew going in that I wanted to completely protect that foam seal from getting wet. I took direction from some of those discussions and "improved" upon the steps in the TSB (IMO anyway).
The TSB only shows to apply 3M 3340 foil tape over the installed elbow, seemingly to protect the elbow from heat (?) This leaves the foam seal exposed to potentially get wet and I wanted to make sure that foam seal stays dry.
Apply heat shield tape over the elbow as shown in Figure 6
The heat shield on my truck had a hole not much larger than the foam seal around the drain tube.
There's about an 1/8" gap between the heat shield and firewall on my truck and I can see how water could potentially get between the firewall and heat shield from above and run down to the foam seal, maybe when driving in a bad rain storm or something. (these two points can be seen in a later pic)
I wanted to apply foil tape directly on the firewall and cover the foam seal completely, so I cut away a section of the heat shield.
Something mentioned in several of the threads I'd read was that the drain tube has a couple ribs on the bottom of it. If you apply the elbow over these ribs, it just creates a gap in the fit of the elbow and drain tube, which can allow water to seep right back to the foam seal - the very issue the elbow is supposed to resolve. Why Ford doesn't address this in the TSB is beyond me. Like others, I used side cutters and a razor blade to trim those ribs off so the drain tube is smooth. The pic below indicates where the ribs were.
I cleaned the firewall with alcohol and applied a piece of foil tape to cover the foam seal. I cut a hole in the tape for the tube to stick thru.
On layer of foil tape may have been fine, but I tend to over think things, so I cut two more strips of foil tape and cut slots in them like below. I then installed them with the piece on top overlapping the bottom piece like shingles or siding on your house. Thinking was to ensure any water that may flow down the firewall can't get under the tape and reach the foam seal.
Bottom strip of tape installed first
Top strip of tape installed last, overlapping the first strip.
I cut a length of 3/8" fuel line about 4" long to extend the length of the elbow. Any water that drains out will exit far away from the foam seal.
I smeared RTV on the OD of the fuel line before inserting it into the elbow.
Then I smeared RTV on the OD of the drain tube and around the hole in the tape, and installed the elbow onto the drain tube.
Next I installed a strip of foil tape over the elbow, as shown in the TSB. I also added another strip of tape at the top of the elbow to create a "hood" over it, so any water that may ever flow down the firewall or heat shield will be diverted around / away from the elbow.
Last, I re-installed the section of heat shield that was cut out and taped it back into place with 3M 3381 foil tape. The 3381 tape has near the same specs as the 3340 tape, but doesn't have the red text on it and looks like all the other foil tape Ford uses in the engine bay.
I thought long and hard about using the 3381 tape on the elbow, but it does have a little lower heat resistance and strength, so I decided to go with what Ford spec'd in the TSB on those areas. If there is ever any discussion with a dealer about it, I used what Ford said to use.
You'll also see in the pic, I made sure the fuel line dumps the water straight to the ground and not on the frame rail, so there's no chance it runs down the frame and pools somewhere and results in corrosion / rust 10yr down the road.
Nice work! I tend to do things same as you, if i’m under there already, i might as well do it the best way possible, cause its my rig, not the customers rig and i aint simply following instructions that were designed for a quick and easy fix by ford techs.
Did you have to take off the wheel an/or raise the truck or are those generic instructions on a TSB?
Agreed, no one will work on MY truck as carefully or with as much attention to detail than I will.
I turned the wheel full left and laid under the truck on the floor. I have the plastic wheel well liners and had my son pull it back and hold it while I had my arm(s) up in there working.
Thanks, I was wondering the same... Seems like it would be a job from underneath!
Yes, i went out to check under my truck. No need to raise it or take the wheel off as OP said, allthough would be easier that way for access, thats why i think TSB had it that way. The wheel well liner, mine are not plastic, and i would either need to take them off (which is a pain) or figure out how to get them partially out of the way, perhaps remove some of the plastic pins holding them in place.
Is this a gas or diesel truck? Because my diesel I can barely even see the thing never mind work on it I’d have to pull the wheel well liner to do anything with mine
It's a gas truck. There's barely any room to work around the gargantuan diesel.
I just crawled under my 6.7L truck, and you will definitely need to pull the wheel liner if you're working by yourself. I circled the spot in red where the drain tube is.
I planned on doing this just as a preventative thing I even have the elbow but screw that lol it’ll be warranty if it leaks let them deal with it
I just posted a picture above your reply. It looks totally doable with the liner out of the way.
Oh yeah I know I seen it and that wheel well liner I’m betting is no treat to get out I just glanced at it but there’s a bunch of harnesses attached to it that I’ll guarantee you can’t see from up top so no idea how to get them back attached after
Yeah but take a look at your liner they used these stupid metal retainers that push over studs that always brake plus all the electrical harnesses with push pins mounted from the top which you just push them out but my concern would be going back in
Hmm yeah, true. Crappy design. I pulled the liner from a 2013 F150 and it was better thought out.
Omg Bronco, what is that lower left hand corner eating at your harness, you need a bath😂
Yeah I’ve pull many liners on dodge/rams for doing turbos and what not, I looked at this one and it was like wtf ford lol
Looks great!
I started preparing to do the TSB for the drain elbow; got all the parts and materials on hand recommended by @number9xd .
I got a piece of 3/8" ID fuel hose from the auto parts store, and my plan is to have the hose direct the water past the frame rail. I've already determined the length and this photo shows where I cut it at the red line. This will also route water away from the wire harness trough above, which will mitigate future corrosion.
