I'm in for one too.
I would use petg because that’s one that I have and I know it’s better than pla, but I’m not sure how it will hold up under the hood with the heat based on some quick googling.Sounds good, I’ll order the OEM part this weekend and work on reverse engineering unless someone jumps in first.
Is there a desirable filament for these from everyone so I can put together run times and material cost which I’ll share. Not looking to get rich, just get paid for my time.
| Filament | Engine Compartment | Approx. Tg / heat limit* | Description |
| PLA | ~55–60°C / 130–140°F | Glass transition far too low | |
| PLA+ / Pro PLA | ~55–65°C / 130–150°F | Still softens/creeps with heat | |
| Silk PLA | ~50–60°C / 120–140°F | PLA plus weaker additives | |
| PETG | ~75–85°C / 165–185°F | Can soften/creep in hot engine bay | |
| PCTG | ~85–95°C / 185–205°F | Better than PETG, still temperature-limited | |
| ABS | ~100–105°C / 212–220°F | Good general engine-bay material | |
| ASA | ~95–105°C / 200–220°F | ABS-like heat resistance; very durable | |
| HIPS | ~90–100°C / 195–210°F | Heat okay, mechanical/chemical properties mediocre | |
| Polycarbonate (PC) | ~140–150°C / 285–300°F | High heat strength; tough | |
| PC blend | ~110–140°C / 230–285°F | Easier printing; heat depends heavily on blend | |
| PA6 Nylon | complicated | Excellent mechanical/heat resistance; absorbs water | |
| PA12 Nylon | complicated | Tough, chemical resistant; less stiff at heat | |
| PA6-CF / Nylon-CF | commonly 150°C+ HDT | Excellent stiffness and heat resistance | |
| PA-GF / Nylon-GF | commonly 140°C+ HDT | Strong, stiff, heat resistant | |
| PC-CF | commonly 140°C+ HDT | Excellent heat/stiffness; expensive | |
| PETG-CF | ~80°C-ish Tg | CF adds stiffness, not much heat resistance | |
| ABS-CF | ~100°C-ish Tg | Stiffer ABS; good for brackets | |
| ASA-CF | ~100°C-ish Tg | Excellent general-purpose engine-bay filament | |
| Polypropylene (PP) | ~100°C+ usable range | Excellent chemical resistance, but flexible/creeps |
Not yet....working it now.Any of 3D printing people have an STL to share?
Is this for the 23+MY?After a few iterations I think I have something workable. Kept it pretty simple. The bolt is temporary and would be replaced with a proper lynch pin. Let me know what y’all think!
Yes this is test fit on a 24. I think it should fit previous years as well though. Need to find one to test fit it on.Is this for the 23+MY?
Judging by your model year rig.
I encourage you to still try a design. It's always good to see different iterations!Looks like others are on the ball with this, so I'm going to bow out. Can't wait to see finished products.
