Vibration issues - Too much Caster?
GreaseMonkey
Tremor Newbie
Virginia
22 F350
I recently leveled my 22 F350 Tremor (7.3) and when I had it aligned my front Caster is at 8deg. I believe the prior owner installed caster shims and my kit had radius drop brackets that also increased the caster. The truck drives great up to about 65 but past that I get a pretty severe driveline vibration.
Could this be because of the excessive caster? Everything in the front end is tight and the tires were properly balanced.
Not sure what else to check but it’s driving me crazy.
Thanks for any help!
its fairly common to have some sort of problem after people try to make the truck more level. ive seen a million threads just like yours. new vibrations. sloppy steering. death wobble. tires wearing wonky.
my opinion has always been to avoid the level trend and keep it more stock.
nothing looks more awful than a level f350 popping a wheelie with a jetski in tow
A lot of folks have also successfully leveled and/or lifted their Super Duties and don’t have problems. Yes adjustments may need to be made to work through some of the issues you mentioned, but it’s possible to level / lift and not have the issues you described given the proper install/adjustments and parts
I second @thatdood! If problems persisted with levels, lifts, etc, aftermarket companies wouldn't be in business. Hell, after going to SEMA again, I might just go 15" with 44's! 🤪
