Viair 2.5 gal. tank mounting ideas w/Carli Remote Reservoir in front of spare tire
Houston, Texas
'22 F350 Platinum Tremor 6.7 AMB/Black
'24 Toyota Land Cruiser FE | '22 Shelby GT500 Heritage Edition CFTP POTS | '23 BMW M4 Comp. xDrive
I'm looking to (FINALLY!) mount my Viair 2.5 gallon tank on my Tremor. I just got underneath it and realized that the space where I had planned on mounting it--in front of the spare tire--is now occupied with the remote reservoirs for my Carli shocks. Understanding that it's probably going to be easier to relocate the reservoirs, does anyone have any creative places that you've been able to mount your air tank without relocating the shock reservoirs? Thanks in advance.
I mounted two of those Viair 2.5 gallon tanks between the fuel tank and the transfer case.
I mounted two of those Viair 2.5 gallon tanks between the fuel tank and the transfer case. View attachment 169962
Obviously, I hadn't even considered that spot. Nicely done! Did you have to fabricate brackets or were you able to use the bracket attached to the Viairs? If you have any further pics of how you attached these, I'd appreciate it. Thanks again!
Bad spot if you plan on a larger fuel tank in the future.
Maybe that's why the spot wasn't obvious to me when I was looking--I have the S&B 60 gallon.
I just took some angle aluminum and bolts them to the tank. Then used some u bolts to go over top of a chassis cross member.
