It's the Swarfworks mount: https://swarfworks.com/switch-pro-rcr-force-12-mount-for-17-ford-raptor/
They have options for both SwitchPros versions (the 9100 and the RCR Force 12)...mine is the RCR.
@OffroadAlliance is a dealer for Swarfworks, or you can order directly from Swarfworks.
Looks great. Where did you run wired through the firewall? To much I can see on the passenger side. Any input is appreciate.
I’m thinking that way also . Im having a hard time bringing myself to drill into the interior. I wasn’t keen on how the Builtright or Bulletpoint are in my line of sight . Oh well the search continues.I really don't want to drill through any interior panels to install the Switch Pros; especially parts that would be expensive to replace down the road. Has anyone used the 67 Designs mounted to an arm and then mounted to a BuiltRight dash mount? I don't mind drilling into that top dash part, as I can always remove it and put the rubber pad back in there to cover the holes.
SwitchPro-SP9100 Switch Panel Holder
This 3D printed nylon device holder fits the SwotchPro SP9100 panel / head unit. Comes complete with the 20mm ball ready to attach to a carbon fiber fixed length arm. (Sold separately)www.67d.com
Ford Super Duty (2017 - 2022) Interior - BuiltRight Industries
Made in USA, Lifetime Warranty. The best engineered, highest quality storage and organization upgrades for the 2017-2022 Ford Super Duty. F-250, F-350 and F-450 solutions available.builtrightind.com
I just installed the SDHQ kit over the weekend. Not done with the electrical but did mount the mount the switch panel. My truck didn’t have upfitters so went this route. Wasn’t that hard just a bit time consuming as you only have one shot.I’m thinking that way also . Im having a hard time bringing myself to drill into the interior. I wasn’t keen on how the Builtright or Bulletpoint are in my line of sight . Oh well the search continues.
I'm 92.5% I'm going with that, did you install it?I did the SDHQ console mount.
92.5% such accuracy. I did SDHQ has a kit and a module mount that goes in the engine compartment. (Instruction suck)I would have preferred to run the wires down the passenger side A pillar but could not find a way to get through the firewall on that side. I’m not done with electrical but getting the plate mounted and wire run to the engine compartment was a big first step. I’ll post more as a get through it. Plan on starting a build thread as this is the first thing I did since there were no upfitters.I'm 92.5% I'm going with that, did you install it?
Looks cleanI just installed the SDHQ kit over the weekend. Not done with the electrical but did mount the mount the switch panel. My truck didn’t have upfitters so went this route. Wasn’t that hard just a bit time consuming as you only have one shot.
I ran everything through the drivers side. There is a grommet that is super easy to get to above the parking brake, or somewhere in that area. Get under there and you cant miss it. Sweet thing about the switch pros is you only have to pass one wire through to the control unit, although it is pretty thick. I did have to get the extended cable in order to get it from the passenger side, across the truck, down into the driver side footwell, back up the apillar and across to the sunglass holderLooks great. Where did you run wired through the firewall? To much I can see on the passenger side. Any input is appreciate.
Thanks, I am running through that grommet as well, the only one I could actually reach. I had just ordered the longer cable as well from Swarfworks. Any insight on what fuses you used? That’s the project for this weekend, get it all up and running. Would love to see how you wired things up.I ran everything through the drivers side. There is a grommet that is super easy to get to above the parking brake, or somewhere in that area. Get under there and you cant miss it. Sweet thing about the switch pros is you only have to pass one wire through to the control unit, although it is pretty thick. I did have to get the extended cable in order to get it from the passenger side, across the truck, down into the driver side footwell, back up the apillar and across to the sunglass holder
Looks like a great install location. Could you share how you mounted the switch pro.I got rid of my worthless wireless phone charger and added Switch-Pros SP9100 in its place. Everything was a pretty simple and easy install and I love the options that the Switch Pros allows.
