Upfitter vs Switch Pro
Looks like a great install location. Could you share how you mounted the switch pro.
I replaced the wireless charger tray with a non-charger tray and used a ShawnTexan F150 switch-pro mount. Door can still be closed over the switches.
Thank you I’ll look into the mount .
I can definitely get down with this setup. Do you happen to remember the Ford PN for the non-charger tray?
I can definitely get down with this setup. Do you happen to remember the Ford PN for the non-charger tray.
KL3Z-1513594-AA is the part number I used from a Ford Expedition. I believe the Expeditions, F150s, and Super Duties use the same tray depending on years. My USB ports, ambient light, and door all mounted perfectly.
KL3Z-1513594-AA is the part number I used from a Ford Expedition. I believe the Expeditions, F150s, and Super Duties use the same tray depending on years. My USB ports, ambient light, and door and mounted perfectly.
Awesome! Thank you!
Awesome! Thank you!
FYI, if you guys want the rubber mat insert it is part number JL3Z-15045G34-AA. Recently changed out this tray as well for mobile radio install.
I have a dilemma that I need help and advice with. Unfortunately my tremor did not come with upfitter switches . I need to add switches to control auxiliary lights and future modifications.
So should I go down the rabbit hole and try to find the proper overhead console and factory wiring harness that is needed to add the upfitter switches? I’ve read that this can be a lot of trial and error.
Second choice is to go with the switch pro and one of the available mounting systems.
I do like the stock look of the upfitter switches.
Unfortunately my truck has about all other options sunroof , advanced alarm, sliding rear window, black onyx interior just missing the upfitter switches.
Sorry for the long post .
Thank you everyone for your help in advance.
I would probably go with an OEM integration package. It's just cleaner to me.
I’m leaning that way also I’m hoping someone has part numbers to help out my search
I am in the same boat as you. I have all the options except the up fitters. I have been looking for a OEM part but see a lot of guys saying parts don't work. Id be intersted to know what way you go. switch pro seems like less of a hassle but the cleanliness of stock seems worth it to me. Either way please keep thread updated if you find OEM parts that work.
Mine did come without upfitter switches as well. Have the Switch-Pros 9100 installed. Just to the left of the steering column. I am happy with that and gives me more options + the phone app.
Here is a video that shows the complete install of the Ford OEM Upfitter Switches.
NOTES:
1. Requires new Overhead Console and two wiring harnesses.
2. Part Number(s) for the Overhead Console depends on OEM options and color
a. Power Moonroof???
b. Power Sliding Rear Window???
c. Interior color???
3. Stop @ 0:49 - 0:56 for Part Numbers used in this video
a. Console - HC3Z-28519-A58-LAV
*found the same number except LBM and LBJ replacing LAV at end*
b. Upfitter Fuse and Relay Panel - HC3Z-14A303-F
c. Wire Assembly - HC3Z-15A404-A
Various Ford online prices for the console range $600 - $700. Fuse and Relay Panel is around $250 and the Wire Assembly is $95 to $115. eBay had lower costs. The Relay Panel installs in the engine bay area.
Best option for lowest cost is to obtain the OEM parts from a salvage yard.
I got rid of my worthless wireless phone charger and added Switch-Pros SP9100 in its place. Everything was a pretty simple and easy install and I love the options that the Switch Pros allows.
Great location for the Switch-Pros SP9100. Clean Look.....will do the same if additional switches beyond the OEM six upfitter switches are needed.
I don’t have the uplifter switches. I spoke with Ford and apparently was told that Ford does not sell the part. He said the only way to get it is to find from a wrecked truck or something like that. And it’s a huge ordeal to install because trucks are not pre-wired for uplifter switches. Not sure how true this is but I just asked about it last week.
They are wrong. 95 percent of dealer parts men will say you can't do it because they can't figure it out or don't want to. Just keep emailing dealers til you get help. Best way is to find a vin of your exact truck trim with the same option like moonroof, rear window, etc, only also with the upfitters.
Then just ask for the parts that vin had.
