Upfitter switches always hot
Mod to make all switches hot, I did mine with this
I'm wondering if this purchase is necessary since OP discovered how to power all switches in post #4?
There was a modification to post #4. After initially doing it and some conversation with others, the OP discovered the parasitic draw of the PTO and Start relays. This is resolved with @BroncOh modification, pull the RUN/START relay. The PTO circuit would not be energized unless the PTO is installed (Or conditional use of that circuit for something else.)
The Limitless harness essentially does the same as swapping fuses and pulling relays without worry about the relays or fuses. It's useful for the plug and play individual that doesn't want to mess with swapping fuses or worrying about other circuits in play, but it is a bit pricey for what it does.
I purchased the Limitless harness for a different reason, I will soon be incorporating it into an invention to set an indicator that show the switches are still on after the ignition is turned off. Not a high priority foe me right now but is on paper waiting for construction and testing.
Well...I can't respond to this. If @Canyon Trekker says it shall be, than it shall be. Just please shorten your response to a sentence. Once I see paragraphs, I get nervous.
Yes, as mentioned above. I have not pulled my upfitter run/start relay or the PTO relay since doing this and have had no issues. The relays do provide a very small parasitic draw and as mentioned, can be removed if the truck sits for long periods of time where that draw can be a concern. I know @Optimus , a long dissertation! Sorry!
Thank you my friend. I will consider all options. The only time I want to draw a parasite is on paper 😁.
