Up-fitter switches expansion harness.
And when it's her birthday or your anniversary and you're STILL ordering parts...
Dang it, I heat shrank everything I ran already and made it look nice but… I need this. Ordered lol. I’ll have the shop install it when they mount my compressor.
Here is another option as well as far as extending the Upfitter wires.
I was just going to screw a din rail on the lid and put some wago blocks on it for connections but chances are they’d get water and debris in them facing up and they’re not super sturdy so any jockeying around in the engine bay runs the risk of breaking them
The OTC stuff is nice, industry standard connectors and all that. And it’s cheap. I’ve spent more on heat shrink splices and ferrules and associated tools than the cost of the OTC kit.
Yep...the box is nice and clean, but if you're looking for just a wire extension, we have an alternative and wire count choices. They have been popular as well:
Upfitter Harness Extension
If I am correct, There are also connections in the cab for the uplifters also. So you can hard wire things like radar detectors. Is this correct?
There’s a couple wires pulled to inside the cab from under the upfittier fuse box that are not connected to anything on either side.
Correct, there’s 4 passthru wires that are put through the firewall for you. They’re a smaller gauge, so I wouldn’t plan on running much though them.
Where they are, and the lengths you get to work with seem dependant upon the day the truck was built, who was on the line at the time, and what phase of the moon happened the night before.
I found mine taped up behind the fuse box under the dash, had to remove the glovebox to access and pull down. It was secured with a few other wires, and not just 4 by themselves. They’re labeled, but it’s just a build code, nothing nice like Passthru 1-4. Under the hood, I found mine right below the computer connectors, above the upfitter fuse box. They were taped together as a bundle wrapped to the main harness.
Connect on both ends, and you’re good to go to have upfitter controlled devices in the cab.
