Here is another option.
THIS ITEM IS NO LONGER AVAILABLE. Please see our Gen2 Compressor. Air up a set of 35" tires in under 5 minutes (with a MF 4 Tire Kit)* 10.6 CFM dual cylinder compressor at 0 PSI 6.5 CFM at 30 psi 150 psi rated PSI Cutoff Switch (80psi on, 120psi off) 50% duty cycle (15min on, 15min off)...
morrflate.com
The TenSix compressor claims to be twice as fast as Smittybilt 2781s, and 58% faster than a Twin ARB.
They are currently on back order pending some changes that includes adding a pressure cutoff switch, and a little better heat dissipation, and a few other minor things (better bag, threaded filter caps, etc.
I put my name on the waitlist. The current ETA is Mid January for the waitlist orders.
