The bump steer is due to your track bar vs. steering linkage (drag link) being at different angles now. To fix this, find a drop pitman arm to realign the two bars. When the front axle is shifted up from impacting a bump, the axle moves slightly sideways from the track bar path. You improved that path with a drop track bar bracket. BUT, that arc is now different than the drag link steering linkage. So one has to allow a shift - which is your drag link, which is connected to and part of the steering. Hence bump-steer.
A new more robust steering stabilizer usually helps in some of this in typical lifts/leveling kits. But in this case, the system has to absorb the variance of linkage paths, which goes into the steering.
More caster is needed on a leveling kit, unless you lower the rear of the trailing/radius arms. The axle gets rolled forward with any lift without lowering the rear of the radius arms, or changing the mounts at the axle.
