Your caster looks fine. But some like even higher caster for more “return to center” help. Too little caster and it can help introduce death wobble.
What click setting/position did you start with?Just installed the FOX ATS and so far made a day and night difference. Thank you all!
I started at 16 then went to 22 and just a few minutes ago, I took it up to 25 clicks (I know it says 24 clicks but mine has 26 clicks). Just got back and so far seems much firmer in a good way.What click setting/position did you start with?
Good info! Guess I should get on the ball ordering one as well. Seems like most people land between 14-20 clicks.I started at 16 then went to 22 and just a few minutes ago, I took it up to 25 clicks (I know it says 24 clicks but mine has 26 clicks). Just got back and so far seems much firmer in a good way.
I noticed that on the lower setting I was still getting the steering wheel to swing from the center when traveling on a straight road with some uneven road surface. I’ll try the new setting more tomorrow on my commute to compare.
I will still look into a drop pitman arm as you suggested in your original post.
Attached is a short clip of what I mean. I believe it’s the so called bump-steer.
On my commute this morning, I noticed the higher the setting the less feel in the wheel on bumps, pot holes etc so definitely satisfied!Good info! Guess I should get on the ball ordering one as well. Seems like most people land between 14-20 clicks.
Thank you sirNice, clean, very tasteful truck!
