B
Backslider
Guest
I have a 2020 F250 Tremor 6.7L with High Capacity Trler Tow Pckg $2730 option.
The front was quite a bit lower in the front, I went with Carli leveling springs for diesel.
In the front the tire to fender measurement went from 8" to 10.125" Just over 2" higher.
The front sits about 0.50" lower than the rear, I did not touch the rear.
My factory front spring part number LC3L-5310-ATA
You should always measure from the center of the wheel hub straight up to the bottom of the fender. This way you don't get varied measurements based on load, tire pressure, etc.
