100% possible. 37s kinda fit even stock, so the carli kit gives you plenty of room.Hi I’m new to the forum and am in need of clarification. I would like to Run a 37 on the factory rims. Is it possible to clear a 37 on a Carli 2020 3.5 in backcountry kit
I looked online and I saw that it says for Diesel truck only, will not work for 7.3. Did you use the diesel kit, the one with Bilsteins?I used the 2.5” ready lift leveling kit for F250. Says doesn’t work with Tremor but it works perfectly. Nose will only have 1/4” rake in front when done as you can see from my truck pic.
I am trying to figure out which lift I need to level my Tremor. Did your eye-holes line up? Anything else I will need?I’m taking the plunge now too. I ordered the ReadyLift 2.5. I originally ordered the kit with the Billsteins but cancelled that one and got the kit with the shock extension brackets. Why ditch the special Tremor shocks? But thinking about it, I wonder if the eye-holes on the shocks are the same as conventional shocks. Does anyone know? I don’t have a stock super duty shock to compare to a Tremor shock. There’s no Tremor trim line option either.
I had the shop install it where I bought it. Here’s a link and I’ll explain why.I am trying to figure out which lift I need to level my Tremor. Did your eye-holes line up? Anything else I will need?
Let me know how it works out for you and exactly what you got when you get it installed, this is what I’m thinking also. Don’t want to touch the front end and I don’t need my truck any taller.I ordered a reverse level from PMF. I had bad luck with my last truck and alignment issues after lifting the front. It eventually got sorted out but after spending $$ so it would handle normally.
Did u get the angled blocks? How was the install? Just blocks and U bolts?I just did the reverse level on my F350 6.7. Rear measurement before roughly 45”, and with 1.5” PMF block it was roughly 43.5”. Bonus is the ride which is noticeably better.
Worked out great. Have 10,000+ KM’s on the kit now. Truck still has a small amount of rake unloaded which I like and with hauling two sleds it sits perfectly level.Let me know how it works out for you and exactly what you got when you get it installed, this is what I’m thinking also. Don’t want to touch the front end and I don’t need my truck any taller.
Looks good. I was concerned that 2.5 would bring its nose up too much, but a slight rake is actually ideal. My 21 Tremor is being built. My 17 F250 SD with 6” Stealth lift on 37’s is awful to drive. The Tremor hits the sweet spot. Thanks for the picsI had the shop install it where I bought it. Here’s a link and I’ll explain why.
This kit is coil spacers and a few other parts like track bar relocation bracket and shock extensions. The Tremor springs and shocks are different than standard superduty. I didn’t want to lose them. The spring just gives height from what I understand but the shocks are much better over standard. This kit extends the tremor shocks and lifted the front 2.5” allegedly. I think it turned out well. ReadyLift would not guarantee this lift would work but the shop had no issues with it. It rides great!
Did you end up needing castor shims for alignment with your setup? Looks awesome ??I had the shop install it where I bought it. Here’s a link and I’ll explain why.
I don’t know if 4Wheel Parts used the shims. Alignment was part of the install package though. Just put the 37’s on today too. I love this truck.Did you end up needing castor shims for alignment with your setup? Looks awesome ??
What 4wheel parts ?I don’t know if 4Wheel Parts used the shims. Alignment was part of the install package though. Just put the 37’s on today too. I love this truck.
What 4wheel parts ?
Oh! LOL. NAPERVILLE, IL #248Lol , no which one did the work ? I work for the one here in Dallas , Tx
Just installed a Readylift 66-2726 on my wife's 2020 tremor. Like others, even though it says it won't work on a tremor its absolutely fine. No camber/caster slugs needed. No death wobble. Stock truck without the rake. Its only $270 on Amazon and comes with the track bar relocation bracket.Hi I’m new to the forum and am in need of clarification. I would like to Run a 37 on the factory rims. Is it possible to clear a 37 on a Carli 2020 3.5 in backcountry kit
