me too. Commuter....Leveled mine with a Carli backcountry system and 37’s.
Love that color.me too. Commuter....
.View attachment 2827
what exhaust is that?
I just did the reverse level on my F350 6.7. Rear measurement before roughly 45”, and with 1.5” PMF block it was roughly 43.5”. Bonus is the ride which is noticeably better.
No it will not fit. Carli makes a hitch set up that will fit a 38” tire but it’s pricey.will a 37 fit under the bed in the factory spare tire location?
Looks great on your ride!AFE, DPF back stainless.
I know the ad said if it moves forward. I did see it on a couple of trucks. So it might be available soon.No it will not fit. Carli makes a hitch set up that will fit a 38” tire but it’s pricey.View attachment 2941
How does it sound? Did you need to tune after installation?AFE, DPF back stainless.
I used the 2.5” ready lift leveling kit for F250. Says doesn’t work with Tremor but it works perfectly. Nose will only have 1/4” rake in front when done as you can see from my truck pic.I am wanting to leave my tremor can’t stand the rake anyone done one on a tremor if so what kind and does it work good? Had mine sense February love the truck. Pulls my 15000 pound camper great
Nice, I looked myself on their website. Lo and behold, I find these pics...I used the 2.5” ready lift leveling kit for F250. Says doesn’t work with Tremor but it works perfectly. Nose will only have 1/4” rake in front when done as you can see from my truck pic.
This is the best bang for your buck to get a perfect level and also improve the ride drastically! We've got a bunch in stock too.Truck looks great. I want it completely level if I can find one so I can run 37-12.50 tires
So if I take it somewhere to do mine just need to tell them RC 1.5” level and ready lift adjustable track bar? Anything else I need to point out or make them aware of?Thanks, I did. When I raised the front it offset the axle a 1/2" to the drivers side. So I got a readylift adjustable track bar. I liked the Readylift because I could adjust it while its on the truck, it doesn't use heim joints and has an upgraded ball joint. Here is the track bar : https://www.readylift.com/track-bar-for-0-0-5-0-of.html
What does a reverse level do and involve if you don’t mind me asking, what’s the take after and how much reverse does it do? I don’t want it completely level for when I pull my trailer, and how does reverse level differ from a front level, new to this help me out thanksI ordered a reverse level from PMF. I had bad luck with my last truck and alignment issues after lifting the front. It eventually got sorted out but after spending $$ so it would handle normally.
What happens when your hauling something? Can you lower the front?This is the best bang for your buck to get a perfect level and also improve the ride drastically! We've got a bunch in stock too.
17-26 Ford F250/350 Eibach Level Kit
Built upon decades of off-road racing, the Eibach PRO-TRUCK-LIFT combines a series of PRO-LIFT-KIT springs and PRO-TRUCK Sport shocks to create a perfectly tuned suspension system engineered for both, on and off-road performance. Each PRO-TRUCK-LIFT is designed and tested to deliver maximum ride...www.neo-garage.com
No, it’s not adjustable, but by my measure even with the Eibach kit you’ve still got about 1/2” of forward rake, so like 1000# on the tongue would still keep it fairly level.What happens when your hauling something? Can you lower the front?
