Transmission Rebuild
Can you tell by these two pic's what month it was built. I was thinking 8-23-22.
Very close!
The label with the QR code in your images shows a transmission date code of 22238.
This 5-digit value uses a Julian date code format (YYDDD):
22: Represents the year (2022).
238: Represents the exact day of the year (238th day).
According to the Julian calendar for a standard year, the 238th day falls on August 26th. This means the transmission was built on August 26, 2022. You made it by 11 days!
Happy Almost Four Year Anniversary my friend! 👊
Very close!
Thanks, Built in Sept 22 but did not get delivered until 12/31/22. Waited 17 months from order to get it. But dam the 22's look good..
Very close!
About to hit 37k miles. Wearing it out. LOL.
hmm, maybe I found the wrong label?
Where is it located?
edit: nevermind, mine is a 23, I'm good
Found it! You have traces of the Double Deuce within you. It's ok. We still like you. "HA"
so what date? March of 22? Do I have the updated?
It's the wrong sticker. This issue only concerns the 2020-2022's. As you stated, yours is a '23 so you're good.
My 2020 transmission has failed. Dealer wants to put in a new one. Would it be wrong to assume all of the new transmissions have been updated ? LC3Z*7000*HB is the part number for new transmission. $12 000 installed.
The broken one has the drum/bushing issue. I don’t think I want to replace it with a new transmission and same issue.
Does anyone have any advice?
Thanks
Thanks
before i paid that much id look into aftermarket solutions, suncoast or WPDevelopment.
It appears to be similar. Suncoast website indicates maybe a little higher. There are a number of upgrades I don’t fully understand.
I think the nearest dealer is Boise. I’ll do more research.
Thanks
Thanks
youre right the price might be similar but they have a lot of upgraded hardparts and better clutches and what not; including a revised CDF drum. I think they also both have upgraded Valve bodies too that avoid the typical failures there
Ok, I have a 2021 F250 HD diesel. I have had for 5.5 years, low miles, ~15,000. Should I look into an extended warranty? I think my current one is only good for 72 months or 60Kmiles.
My friend, I know exactly what's going on here. Since we both run the 7.3L with that 10-speed (the 10R140), I keep a pretty close eye on the quirks with these powertrains.
What you're dealing with is a widely known failure with the CDF clutch cylinder (that’s the "plate" or "bell" the dealer is trying to describe to you). Inside that CDF drum, there is a pressed-in bushing. Over time, that bushing slips or "walks" out of place, which blocks off the hydraulic fluid passages. When the transmission loses that hydraulic pressure, it causes those brutal, clutch-popping shifts—especially on the higher gears, skipping gears, or slamming into lower gears at parking lot speeds.
Ford actually has Technical Service Bulletins out for this exact problem because it’s so common across their 10-speed lineup. As for why they won't just drop a whole new transmission in, you actually want them to do the rebuild, and here is why:
Warranty Protocol: Ford's warranty requires dealers to tear down and replace the specific failed internal components rather than tossing the whole transmission if the case and gears are otherwise fine.
A "new" transmission might have the old problem: If they ordered a full remanufactured transmission off the shelf, there’s a good chance it would be built with the older, defective style of the CDF cylinder. You’d end up back in the shop in another 50,000 miles.
The Permanent Fix: The rebuild they are offering involves installing a brand new, redesigned CDF cylinder. Ford updated this part so it now has a lip and tighter tolerances that physically prevent the bushing from ever walking out again.
Let them do the rebuild. Make sure they use the updated CDF clutch cylinder (the newest revision of part number LC3Z-7H351-B) and ensure they clear out the TCM adaptive shift tables when they put it all back together. Once it’s rebuilt with that redesigned drum, it’ll shift like butter and you shouldn't have to worry about it failing again.
Good luck and keep us posted my friend!
Couldn’t have said it better myself. 💯
Currently living the same nightmare. However my symptoms weren’t as bad. Should have truck back by next Thursday.
It’s the 10 speed period. Across the board! Mid ‘22 and older. Does not matter if it’s a 1/2 ton to a 1 ton. The TSB is nonsense, honestly should be a lawsuit at the point!
If you have a 10 speed with that time frame. I suggest you have it taking care of. If not it’s just a matter of time! Mine started with a jerky down downshift in 4th gear.
Damn brother, sorry to hear this. Keep us posted on any information! Hope everything works out.
Depends on the warranty cost. I don’t have one and probably should. I think my warranty purchase price in February of 2020 was pretty high. $7500(?). I might be crazy but it seems like it was in that range. Financed, I would have paid quite a bit. I gambled and lost but not by much, as some of the money I didn’t spend ended up in my IRA over the past 6 years, so it’s close to a wash.
Long winded but I say it’s up to you.
Your tranny may be on the clock. What is the cost of the warranty now?
Good so far. Blessed to have in-house connections. CCV and all are being taking care of. Let’s just say repair bill, no warranty is close to $9,500!
I’ll reiterate…..if you have a 10 speed in this time frame. Your trans will eventually take a “walk”! 😠
My 2021 7.3 has 72k miles if this does happen will the check engine light go on or would I find out by how the transmission shifts? I have an extended warranty I’m still a bit concerned.
No. Just be aware of any unusual shifts or gear changing. Skipping gears is normal. However I alleviate that by running my exhaust brake.
I have a 2020 under extended warranty, only 38k miles on it and shifting seems ok for the most part. Since this is a known issue that will cause a problem will they replace the drum or do I need to "encourage" it to fail before warranty is over.
Encouraging never hurt a thing!
What the hell good is the TSB anyway? It doesn’t serve any purpose for the customer does it? Or do they take some kind of preemptive action for people? I
Just wondering.
Just wondering.
It’s a joke is what it is! Basically a “I told you so” but F$&k U! Where not fixing unless you complain! The goal from their prospective is to wait till you push yourself out of warranty and fix THER problem your damn self.
