Tracking module ( telelogical module I think )
Abe Fromen
Sealy,Texas
Army, Army NY National Guard , Retired Air Force '84-'04
'24 XLT w/ XLT package Antimatter blue
1977 Land speeder
Can someone please give me info on what I loose if I disconnect the tracking unit ? And any other info would help also.
wow nobody bit on this one OK I will carry on, as I was
Sorry, just saw this.
Assuming you’re talking about the factory Telematics Control Unit (TCU) / FordPass cellular modem, here is the breakdown for a 2024 Super Duty:
What you lose:
FordPass app features: Remote start, lock/unlock, vehicle locator, tire pressure/fuel status, and vehicle health alerts from your phone.
Factory built-in GPS / Navigation: On the 2023–2024 Super Duty, the TCU handles the truck's GPS signal, so unplugging it or pulling the fuse will disable the built-in factory navigation.
Built-in Wi-Fi hotspot and connected services (like live traffic/weather on factory nav).
Cellular Over-the-Air (OTA) software updates.
Modem-based data reporting and connected emergency/crash notification features.
What still works normally:
Key fob remote start, lock, and unlock.
SYNC 4 screen, radio, SiriusXM, Bluetooth, Apple CarPlay, and Android Auto. (Navigation through CarPlay or Android Auto still works fine since it uses your phone's GPS.)
Everything mechanical and safety-related: The truck starts and drives completely normally with no Check Engine Light or warning messages on the dash.
Other helpful info to know before doing it:
Software toggle vs. physical disconnect: If you don't want to pull parts, you can turn off connectivity and data sharing in the screen under Settings / Connectivity / Connected Vehicle Features. That makes it easy to temporarily turn back on if you ever want to pull software updates.
How to physically disconnect it: You can either pull the Telematics Control Unit fuse in the interior fuse box (passenger-side footwell—double-check your owner's manual diagram, as it's commonly fuse 38 on the '23–'24 models) or unplug the TCU module itself, which is mounted behind the passenger-side rear seat back on Crew Cabs.
How to confirm it's off: Once disconnected, the FordPass app will show the truck as offline/unreachable, and the Vehicle Hotspot setting in SYNC will stop loading or appear disabled.
Silent fault codes: Even though no dash lights come on, disconnecting the TCU logs a background "lost communication" code (DTC) that a dealer or FORScan will see if scanned. If you ever take it in for electrical or SYNC warranty work, it's smart to reconnect it first.
Claim your points first: If you bought the truck new and haven't claimed your FordPass Rewards purchase points yet, grab those before cutting power to the modem.
Quick note on aftermarket trackers: If you're actually referring to a dealer-installed GPS tracker (usually plugged into the OBD-II port under the steering wheel or tapped into wiring under the dash), removing that won't cause you to lose any factory truck features—just check your financing or lease paperwork first to make sure the lender doesn't require it.
