TPMS LIGHT
ALS BOSS CLONE
Tremor Fan
Rapid City S.D.
Army
#1 2022 F250 Tremor, Lariat, Ultimate PKG, 6.7 Powerstroke
#2 2011 Audi S4 3.0 Supercharged 6Spd, #3 1969 Mustang Fastback, #4 2014 Harley Davidson Street Glide
I keep getting atpms light after about 32 mile of travel, then eventually it will reset then come back on, had it to dealership and they replaced bcm in it asit kept setting a front camera code everytime tpms light came on, also has all new tire sensors in it. Anyone else have a problem similar
Okay...what it the tire PSI reading on the dash compared to what you know your tire PSI is at the tire?
No it doesnt read tire pressure on certain tires when it does it, never the same tire, reads normal going back and forth to work, but if doing a trip over 30 miles it will do it every time tires read but maybe 1 or 2 just dashes for pressure.
My light starts coming on after 20 minutes of my headlights being on. It started after I installed Recon blacked out clearance lights. Apparently they interfere with the reading. I've just learned to live with it. The light on the dash starts flashing and I lose all tire pressure readings.
So what's the actual tire PSI??
It is 60 psi cause that is what is set in the bcm.
I think he means check the tires w/a pressure gauge and compare that to the dashboard reading you see in the gauge cluster screen.
It is reading and correct, just like tonight i went to Hill City which is 32 miles away, almost into town right front sensor reads just dashes, had dinner and after an hour we left and it is reading again.
Well it has 4 new sensors in it, they are 4 months old, and it is not just the right front, when it does it it is random, could be front could be rear, could be right or left, sometimes it could be 2, maybe 3, or all the sensors go out and show dashes where it is supposed to show psi, always resets if i stop for over an hour, or if i drive on a real long trip it will reset itself. When it does it I have had ot at dealership and they scanned all the tires and they are reading, just not on dash.
Ok that is good info. The TPMS module should be diag’d next.
I have it set in bcm for 60 all the way around, tires are reading 62 with gauge and showing 62 on dash.
I use it alot, as I drive long trips and pulling an enclosed trailer all over I have sensors on my trailer as well.
I do understand that is can certainly come in handy but because I air down so much, it was better for me to to disable it.
If I got down and air down to 20#, I knew that and didn't want a sensor telling me my tire pressure was low for 60 miles of off-road driving.
Also, I keep my tires all with different tire pressure (front/rear, respectively) and I do that because that is what works for me. Again, I don't need a sensor or computer telling me 50# in the back is low. It is not low - that is exactly where I want it.
I actually like the alerts because they saved my ass twice in my work truck; not that a tire was lower than normal in general, but it alerted me twice when I caught sidewall damage and had a rapid drop in pressure doing 65 plus in traffic on the highway.
The first time I saw it, it was happening so fast I thought it was a malfunction at first. Both times it gave me just enough time to get over to the side before the tire gave without causing people around me to over-react to a high-speed run flat with me working on keeping a straight line while not causing an accident in the process. Just sayin'.
