Tire wear questions.....
Evil Roy
Texas
2025 F250
So, coming from a GM HD with IFS and frequently doing tire and wheel balancing, do solid front axle trucks require the same frequency of rotation. I typically took it in for service every 5-6000 miles and my tires still cupped after about 18 months and 30k miles. I'm in the market for wheels and tires, and contemplating for more budget friendly tire as opposed to the usual Nitto or Toyo if they are only going to last me 2 years.
I would still rotate them every oil change no matter what. Cupping is one or a combination of three things, usually.
Poorly balanced tires.
Improper alignment or worn steering components.
Worn shocks or other suspension components.
I have never had a set of tires on a solid axle truck that I didn't wear out before damage to the tread. Usually 50-60k miles.
Having had lifted GMC 3500 and Suburban the IRS is more prone to cupping than the solid axles. Am still running stock wheel/tire combo, balance and rotate every 10,000miles. I now have 30,000 miles on truck with no cupping on the tires.
I have added Balance Masters, https://www.cjcoffroad.com/products...ug-wheel-balancer?_pos=1&_sid=29c6ddd64&_ss=r, they've really smoothed out the feel of the truck especially at 75-80 which are normal highway speeds here on I84
^^^ This...and I think it's going to be echoing here quite a bit.
^^^ This squared.
I also run Centramatics and have on all 6 F-250s that I've owned. I still rotate every 5000, my OCD compels me to, and I have them road force balanced along with running the Centramatics. Prior to my current tires, I ran through 3 sets of Toyo OC ATIII's and got to 45K on each of them. The only reason I swapped them out was because my rigs sit out in the sun and I don't want to take the chance. Otherwise, I would have put more miles on each set.
I am about 55k on my current Les Schwab brand open ranges. Will get new tires at the 100k mark so only 4k miles left to go. I rotate every 5/6k miles
