Tire rub
surfscottydog
Tremor Fanatic
Santa Cruz California
Handsome Jack. 2022, F250 Tremor with Four Wheel camper, Fleet, White Knuckle rock sliders, Buckstop rear bumper. All the bells and whistle‘s that I might need
Subaru Outback
I’m finally replacing my worn out Duratracs. Keeping the same rims, just get new tires. I’m thinking of getting Mickey Thompson Baja Boss A/T 35X12.50R18. My question is. Will they rub?
Does anyone have these and if so do they rub at all, on road and off road?
Those will be a very slightly shorter overall diameter (fractions of an inch shorter) but will be over a full inch wider than your originial 285/75-18 Duratracs.
<--- Captain Obvious, here, says, the thing to do is to go start the truck and however you think best, turn the steers to full lock. Have a helper hold the wheel gently tight to full lock (don't strangle the power steering pump by going hard over). Get up under there and look to see how much space remains. You will want to see at least 3/4" space (since the Baja Boss A/T will be 1/2 wider to the inside as well as the outside of the sidewall and tread "shoulder".
You should be good to go, but you'll want to look for yourself. Now, when your suspension is in full articulation/crossed up is when you'll want to have another look see, but unless you're off highway or can run it up a on top of some solid elevated object it's going to hard to determine.
Of course others here who have already mounted a 12.5 or even a 13.5 35" tire may tell you "no worries! You'll be fine."
Maybe this size would be better?
LT295/70R18
they say 8.5in minimum width for a 12.5in tire.
you'll get poor handling & bad uneven tire wear.
step up with some wheels too. then you can adjust with off-set.
I run the Legend EXP’s in the same size on factory FX4 18s and they run great with zero rub.
I’m not doing any body work for tires. And I’m not going to tolerate any possible rubbing.
So, flip flop time, plan B.
285/75R18 Toyo Open Country RT Pro.
They do, but then again some 12.5" wide 37s have an 8" wheel at the beginning of the recommended wheel width spec:
Gotta click Specs once on that page ^ ^ ^
BFGoodrich HD-Terrain T/A KT 37 X 12.5 X R18LT​
Whereas the KM3 in the same size states 8.5 -11" for Rim Width Range
8” is fine. I ran some Pro Comp X Terrains that actual width was 13.2” on 8” wide steelies. I ran 37” Krawlers on 8” stock wheels and 3rd gen Ram wheels. I ran 42” x14” Iroks on 8” wide beadlocks on my 2nd Gen Ram.
Worse yet probably I ran 285s on my 6.5” wide OEM Chevy 2500wheels and 33x12.5 on my Ranger 7” wide wheels. On my Power Wagon I ran 35x12.5 on my stock wheels. Wear may or may not be optimal but I doubt 8” versus 8.5” is noticeable when driving .
I still have the 305/70r18 baja boss AT but swapped them from the stock rims to an aftermarket 9" rim. They didnt rub with either the stock wheels or the new 18x9 +18 wheels. They were great in the snow the first year but the siping only goes half deep so you lose some of the wet/snow traction when they wear down. Heavy tire, decreased my MPG by @1 mpg. very sturdy and tough tire though if you need offroad durability and not very loud. Its a very rare combination of good mud ejection, durability and noise levels.
Likely going with a toyo next time (37") since I now have a carli kit installed and the 35's look too small visually :rolleyes:
I have no idea if that size will rub or not but if it's clearance between the bumper and tire you could look at something like this https://sbfilters.com/products/bumper-spacers-3-4-2017-f250. These allow multiple staking so anything from 1/4" to 1-1/4" of additional space is possible.
Oddly I just saw an Instagram, I think, video of them talking about these today when running 38s but I didn't pay enough attention to the details of his convo.
found an older YouTube
