Technical question for the audio video geniuses in the group
BarryGedman
California
USMC
First Responder
Retired Deputy Sheriff
2027 F350
I was looking at installing a dash cam system in my truck mainly for security purposes and accident documentation. It’s a must for me after having my skin saved in two on-duty crashes by the in-car camera video proving I wasn’t at fault. Plus I live in CA and we give drivers licenses to people who don’t have a third grade education. Anyhow, I settled on Wolfbox and saw that they have or are developing the “flex pilot” system, which is essentially a system allowing 4 channel recording with multiple cameras.
Now the question for the people who didn’t spend high school trying to be funny. Would it be possible to take some of the already existing cameras on the truck, IE the ones built into the side mirrors and the bed view camera and splice into/wire those to the Wolfbox head unit, rather than mounting their included Wolfbox cameras all over the truck? It seems like it should be possible and would yield a much cleaner, more factory look, particularly on the side cameras. Any input would be appreciated particularly if you have done something similar with your Super Duty with this type of camera system. I would also appreciate anyone’s opinions on better camera systems for my intended purpose. Thanks and Link to the product below.
Very good question. Short answer; no.
Proprietary camera systems can use different types of interfaces and compatibility would almost have to be experimental as each manufacturer will have their own formula for the interface.
But here's the real issue: Cameras typically work on an NTSC video format in USA. Older formats were using 4.2 MHz but today's stuff is generally the higher frequencies; at high frequency video format around 742.5 MHz and about 2 Ghz bandwidth.) The signals are generally 1V video and are usually shielded with special cables to reduce noise and have low loss. You can't "splice" into an RF shield and have it work efficiently, and there is no guarantee that the two cameras are working on the same video platform. One could be 4K, 1080P, 720P, HD format, (another type of 1080P) different codecs (H.264, HEVC, VP9, AV1) for digital signals, and the systems making Ford vs. Wolfbox, possibly be different rendering the cameras incompatible. They may use the same technology but is likely proprietary information.
This is not talking about wireless; that's a whole different bailiwick. I am talking generally "low" frequency direct connect video signals. (Like in our trucks) The Wolfbox uses several different cameras and assuredly different codecs for each.
To even try to use the cameras on the mirrors, you would likely need to disconnect them from the Ford system and then reroute the Wolfbox interface cables using proper RF connections. This is not easy to do if you've never done this sort of thing before. I have made video, microwave, small signal, and many different types of cable interfaces in a former life (retired now) and it takes technique or an ounce of luck. 🤣
As for what to use, I installed the Wolfbox three camera system myself and am happy with it, but it has its quirks. It's not as good as the big screen cameras on the truck, but my truck didn't have the cameras, so it was a perfect upgrade for me. Originally, I installed a Garmin GPS with a camera option. It worked but only had one camera and not able to reverse the video. I've also experimented with Amazon type cameras and many of the available camera's interface with the displays, but they are all generally garbage. (Low resolution and older analog signals. But they work.) It's also possible to use wireless cameras. Shop around, there are some better-quality cameras out there. As for the security setup you speak of, the Wolfbox seems ideal.
Other Examples:
https://www.rearviewsafety.com/ I've purchased cameras from this vendor before, good stuff.
Here's another I found online, cameras look similar to RVS above.
Hope this helps.
BTW, I did get through third grade. 🤣:LOL:😁
Other Examples:
Hope this helps.
Jesus Christ on a motorbike! I know who I’m calling next time I film a porno. Thank you brother! Excellent demonstration of my audio video ignorance. Bummer it can’t be done. I really want the side coverage but don’t want those ugly cameras 3m taped to my fender.
touches on a wishlist item i have.
i wish the oem cameras had record capabilities. with a removable sd card.
if you didn't want to record, just don't have a card in the slot.
it'd be a nice feature.
i wish the oem cameras had a record capabilities. with a removable sd card.
Just like it works in Tesla. It is very convenient, and you can pull up the cameras on your phone remotely as well.
That type of system, and a digital key for my phone are two wish list items for the truck.
Yes exactly
Exactly. It’s one of my favorite features on my model S. It would be such a great feature to have on a big truck for when some inconsiderate fucker inevitably dings the door and just drives off.
