Stuck passenger side hub
Explorerinil
Tremor Aficionado
Illinois
First Responder
Police
2026 F250 Tremor 6.7
I rotate my hubs from auto to lock at every oil change, today I attempted to rotate my passenger side hub and it was stuck. I have also noticed a clunk sound when hitting a bump at slow speeds. I put a pair of pliers on the hub and with allot of force I was able to rotate it, I have since noticed the clunk sound is gone. However I definitely need a new hub. Where is the best place to get one? Should I go with the warn hubs? I appreciate your help.
Don't replace just one, warn hubs are excellent, but be aware your vacuum system will not activate. You will have to get out (manually) engage and disengage them. But you most likely will not experience thus situation again.
Valid point on the warn hubs! I’m at 52k, I plan of keeping the truck to 100k, so maby I should just get the ford oem hub. I just bought a new turkey gun… not sure if I want to piss the wife off or not😬
The ford hubs get corrosion around the plastic piece that you turn and it causes it to stick. Super common. Seems like ford could come up with a better system
Thank you Arizona for not giving me this problem. However, please do something about the heat in the summertime. :ROFLMAO:
"Yea" for Warn hubs? "Yea"
I am in Arizona and I tore through Ford's plastic mechanism at 8K. Went with Warn Hubs since; the price difference is minute and never will you have that problem again. Do you have to get off and lock the hubs? Yes but typically this is get off and take a leak time and it is also a fail-free system and leaders in the market.
Ford wants $180 for the pair
Warns wants $400+-
Hub lockouts are covered under 60k powertrain warranty. I had one swapped at 38k and one at 55k. Takes longer to get the wrench out of the tool box then to swap it.
But you had to leave it at the dealership for the swap? How long was that?
So I called the dealer today, they told me the hubs are covered under the powertrain warranty. They also said they would get it done this week if I wanted (good ford dealer near me). I debated on the ford performance hubs, but since this is free I’m going too have them warranty it, if it was not covered I would go with the ford performance hubs. I will also mention next year I’ll be ordering a new truck.
