Stuck in Reverse. Won't shift to P,N or Drive!
What is your take on why we haven't heard this situation more often up north?
Most folks have heated garages up north that fit these trucks. Just park it and the slush melts overnight. Slush impacts just about all vehicles especially when it freezes back up, but it has to really be the heavy wet slush.
Mine sits out year round. I don't have one of these heated garages nor one that fits this beast. Maybe one day.
And. Success. Couldn’t go to sleep until this was resolved. Put on rain gear, put down a tarp and laid on my back in the slush with a headlamp on. Removed all the packed in slush and MAGIC. shifted to park. Started. Drive around the block.
Back in business.
Thanks to all who offered advice. Helped a ton.
My son is working in Kansas. He has been driving in a lot of snow with his 2023 F350 diesel. He has not experienced this issue. I wasn’t sure if something was different between the gas and diesel.
Seems to be isolated, very strange.
I'm not shocked at all. Keep in mind he's in the DFW area. The snow he received was likely what we got here in OK, very wet.
The temps have been hovering around the freezing mark which means its not difficult for the snow to slush up then refreeze.
Its SUPER common here in OK to see tons of buildup on vehicles when it does snow because its typically the wet type. Heck, i remember my dad getting onto us as a kid when we would try to kick it off b/c he was so afraid of us bending a quarter panel.
Having said all that...it is interesting the snow managed to build up in that location. Granted, the cat is right there so it was super easy for it to melt and refreeze.
Back in business.
you might slather the effected area with some cold weather lubricant, even some WD-40 Blast should retard the slush from sticking in the first place.
Glad you got it sorted, Well Done.
Slush packed up there like a snow cone. And it was a quick drive so it never really "heated up".
That's my theory. This wouldn't likely happen with proper snow.
I believe the conditions have to be perfect for it to happen. That would include driving through the slushy napalm sticky like icy snow mixture. That stuff will cover the underside of your vehicle and cling - and refreeze. The fact that it was a short drive may have added to it - as the truck may not have reached operating temperature on the transmission.
Totally agree @Vermonster ! It was the (Im) perfect scenario for this to happen.
All good on the drive to the office today. But I did park somewhere that would make crawling under the truck a bit easier should I have to remove more frozen slush!
You might want to consider some mud flaps. I have been running in heavy snow and slush in NW Montana without any issues. Running the Ford/Gatorback flaps.
You might want to consider some mud flaps. I have been running in heavy snow and slush in NW Montana without any issues. Running the Ford/Gatorback flaps.View attachment 186572
Probably not a viable option for him with as much off roading that he does along with snow is not a regular occurance in the DFW AREA.
Drove 10 minutes to the coffee shop and 10 minutes back. There is snow and slush on the ground and alot accumulated on the truck while driving
Got home and went to back into driveway and it would only shift back and forth between N and D. No reverse and couldn't get to P
So drove to front of house and parked in street and tried again. Same issue but then got it to R. And now it won't shift in or out of R.
I did manage to get it turned off. Let it sit
Now it won't start because it's not in P or N
Anyone experienced this? Google results say get it to dealer / shop.
I joined just to reply to this post. I don't have a solution, but I had the exact same problem yesterday (1-9-25). I drove from Fort Worth to Blue Ridge and the roads were covered with snow the entire drive. My last bit of the drive was up a long rock driveway that had over 4 inches of snow. When I got to the gate to get out and unlock it, I could not get my truck out of Drive. It wouldn't shift up or down (2024 Ford F350). I took it in and out of 4 wheel drive but the shifter wouldn't budge. I couldnt even get out to open the gate because I couldn't kill the engine or get out without the truck driving forward. I called a guy that works for me that also drives a Ford F250. He said that he had that exact same problem today driving in the same kind of snow conditions. He said after a few minutes rocking the shifter back and forth it finally went into Neutral.
I did the same and I finally got it into Neutral. After getting through the gate and finally getting to the house, I got it to shift into Park.
There is something under the truck that the snow and slush interferes with to keep it from shifting. Not a solution, but its not some freak thing that happened to you.
Great first Post! :) Welcome!
The Gatorbacks are expensive but you remove all 4 in about a minute without any tools.
Seriously makes me wonder what is it about this particular snow storm that all of the sudden everyone is having this same problem. Maybe some specific conditions ok the road that just didn’t line up in prior snow storms.
Just an FYI for anyone else wondering. I went to the car wash and pressure washed the transmission and my problem cleared up. Snow and ice built up on the actuator on the let side of the tranny was the problem
