Spray In bed liner questions
Linex has 3 different levels of spray in bed liners. If we are all comparing cost we should mention which version our cost was for. 😁
Good call. Updated my post. ...also, I was wrong about the cost. It was $699, not 600.
Are the different levels of protection based on thickness or do they use different compounds?
Just had the premium sprayed onto mine.
This is correct. Standard and premium are identical except for the special UV top coat. Platinum is a different compound (XS-350). Many installers will use the term platinum and premium interchangeably, so make sure if you pay for platinum you actually see them use buckets labeled XS-350. Mike at Linex of Round Rock explained this to me.
I’ll second this. I just had the premium compound sprayed in mine after requesting platinum. There are differences in tear strength and hardness. Regardless I am extremely happy with the premium product.
Extremely happy with platinum or premium? lol
If they do spray over the bolts, if you ever want to remove them, use a utility knife to score around the edges of whatever you are removing so it doesn't peel off the spray. FWIW, I used Line X and they removed the bolts.
Lol! I tried to catch the mistake before anyone caught it. I will say that the difference in cost between the standard and premium was negligible. I paid 628 before taxes.
Haha good times 🤪
Standard is what I’m looking for.
Premium was around $600 for me. I think it’s worth doing that level for the UV protection alone. Unless you carry tough loads (wood, concrete blocks, etc) in the bed, then I would have gone platinum.
That’s why I went platinum. With RV life, we throw shovels, firewood, and rocks in the bed all the time. I also have gas cans and generators that leak oil. I guess for not being in construction I’m pretty rough on the bed.
I also had my spray-in bedliner cancelled, even though it was on the initial order. Line-X here in north Idaho removed all the bolts, taped over the lights, removed the tie downs and took off the tailgate. Came out looking great. Only complaint was when the idiot that drove it around the corner to me, threw it in park before it came to a complete stop. But, that’s a separate issue. Line-X FTW.
I am having my truck spray-in liner installed this week (Ford omitted this from my factory order). The local installer claims he sprays over the bed bolts. Does Ford do this or leave the bolts exposed? I read somewhere that the installer was simply “lazy” if he did‘nt remove the bolts. If the truck ever needed the bed raised (fuel tank/drivetrain repairs?) that the bolts would have to be chiseled/butchered out. Any thoughts on this?
Also does anyone have a pic/or opinion on whether to spray bottom back edge of the bed between the tailgate? installer also says he does not remove the tailgate.
I’m just hoping for best job possible.
My local dealership covered the cost since it was on the initial order. Hopefully they did the same for you. I paid an extra $100 for the UV layer
I had the toff bedliner from ford in my 2017 f250. It was not near as good as linex that I have in my 2022. The toff bedliner was sprayed over the bolts and the liner peeled off the bolt heads within the first 2 months of use. It was applied real thin from ford.
my old truck was linex they didn't spray the bolts and they rusted. the two trucks since were ford factory liner and they were sprayed over. one of the truck the bed was hit in an accident they scraped the bolts to remove and repair the bed then after they resprayed the bolts. if it makes you feel better there are no drivetrain or fuel tank repairs that aren't done from under the truck. only reason they should need to take it off is gooseneck hitch, frame, or bed repairs.
I added a B&W Turnover Ball gooseneck hitch without removing my bed. They are designed to be installed from underneath.
I had line-x installed on my 22
They removed the bed bolts and sprayed between the bed and tailgate down about 3/8” very clean job . I’d search for a line-x dealer in your area .
Seconded. I had the same done and really happy with it.
I got Linex and they went over the bed bolts only. All other hardware was removed.
Totally lazy! Mine was done aftermarket as well and they specifically told me that they remove the bolts and spray then re-install so it’s nice and clean looking. Find Anotjer installer
I am literally at an installer for line x right now. They asked and gave me the choice. I opted to spray over the bolts. I will be checking the area between the tailgate and the bed- thanks for that tip.
I had the TOFF Liner installed on mine. They were also installing the B&W flip ball hitch for me. They sprayed over the bolts and installed hitch from under the bed as well. I'm not worried about UV protection since I have a tonneau cover over it most of the time.
I had LineX in my last pickup and it was great. They sprayed over the bolts but removed the tailgate, LEDs, etc to get it done clean. Pretty sure the Linex is a couple hundred more than the OEM spray in. My current F250 has the factory spray in. It's been a while so don't quote me on this, but I think the Linex went on thicker and had a bit more grip to it (not that I have grip issues with the factory liner either). Also I'm pretty sure Linex prep scores up the paint on the bed before application for better bonding- I doubt Ford does that (unless anyone else knows otherwise). So hypothetically it would be easier to peel up the OEM stuff (saw on some YT video a while back). I haven't had any issues with the OEM stuff though as it does it's job and the Linex dealer is about an hour drive for me, so I'd probably go with OEM if I had a say in advance due to sheer convenience (laziness). The only thing I really use my bed for is split rail fence, bails of hay/alfalfa and occasionally some lumber or mulch. If you're really beating on the bed then maybe it's worth swapping over to Linex, and obviously if yours is naked then your options are a lot more simple.
