I think actually, the correct tire circumference is used in that equation, no?Edit: I can’t remember for sure if it allows you to use non-standard axle ratios. If it doesn’t, you’d need to move it down to the next lower standard ratio (from the example above it would be 3.55) and then move the tire circumference as well.
(Standard ratio / calculated ratio) * tire circumference
From above example: (3.55/3.62)*2699=2644
-So if this was required you’d use 3.55 axle ratio and 2644 tire circumference.
for 37s it is in the 2770 range
