Count me in.Haha, I am a little curious as well
326 bucks for plugs is crazy.![]()
Shibby Engineering Tuner Harness Plug Kit, 2023-2024 Ford 6.7L Power S
Shibby Engineering Tuner Harness Plug Kit.For 2023, 2024 Ford 6.7L Power Strokezzdiesel.com
Are you talking about this kit and the green plug in it? I have this kit installed if so.
ASAP has a kit for $105 (20-22) or $125 (23+), more palatable than the Shibby kit. Seems to work fine.326 bucks for plugs is crazy.
That's nothing. You should see what my girlfriend has spent on plugs326 bucks for plugs is crazy.
They are $150 less direct through Shibby.326 bucks for plugs is crazy.
All these girls trying to remove hair and yours is getting plugsThat's nothing. You should see what my girlfriend has spent on plugs.
Yep, that is the part the green cap is mounted in the pic I attached on this thread. Your shop must have removed it then.That is going to be where that green plug goes. I've got to find the thing though, and I strongly suspect that it is in a box of parts 300 miles away that are not currently in use on my truck.
Looks like it normally mounts via an interference fit on the EGR cooler.
Anytime my friend!Yep. Thanks for the assist. Much appreciated.
