If you get rid of the main service, then you can just use the mini roam plans, $50 for 100gb, or $120 for unlimited for the month. Then throw it on the $5 standby when you are not traveling.
Replying to my own post. I experimented on the drive home today. It did eventually disconnect when in motion. Not sure if time moving, speed, or both are factors, but first 5 minutes was below 30mph and no disconnects. After stoplight, was 55mph zone and disconnected a few minutes at that speed. I arrived home and by the time I pulled in the driveway and drove the 100feet to the shop and came to a stop, it reconnected within a few seconds.I've not experimented with ours, but will be interesting to see what speed they consider "in motion". So far, the examples I've seen where it errors are at highway speed. Will be interesting to see if typical trail driving speeds are slow enough not to trigger the limitation. Below 20mph? Below 10mph? or will only work when absolutely stationary? I guess I could fire up mine and test it. Maybe sometime this week. I usually don't use it in motion, but will give it a whirl as I'm curious to see this new "not available while in motion" error and see at what speeds it kicks in.
If it’s the free mini, you also have to pay for it to use with a plan on its own. The “free” mini and discounted plans are only for with a residential dish on the Max plan.If you get rid of the main service, then you can just use the mini roam plans, $50 for 100gb, or $120 for unlimited for the month. Then throw it on the $5 standby when you are not traveling.
Mine was not free, discounted about 10% or so so I should be good there.If it’s the free mini, you also have to pay for it to use with a plan on its own. The “free” mini and discounted plans are only for with a residential dish on the Max plan.
You will need the Roam plan. Starlink antennas have a GPS receiver inside and they know when you are outside your home zip code.Just run my starlink on unlimited plan at home, and take it on the road with me in the RV. I need to look at all the numbers to decide.
Yes, you are correct. The unlimited plan allows for mobile use. We used this on a trip to and from Alaska.You will need the Roam plan. Starlink antennas have a GPS receiver inside and they know when you are outside your home zip code.
Yeah, we suction cup the mini to the sunroof and have connection anywhere while drivingSo.
I know nothing about these things.
How much would it cost to get a reliable signal to use my phone at speed?
Over 3/4 of my commute is through no cell signal zones.
I’d be a little nervous about losing with only suction cups holding it on at 70+mphYeah, we suction cup the mini to the sunroof and have connection anywhere while driving
I think it's inside the truck, underside of the sunroof.I’d be a little nervous about losing with only suction cups holding it on at 70+mph
Got the same email today!Got an email today that beginning next month the price of Standby mode is doubling to $10/mo. I am sure the next move will be to charge you every time you want to reactivate. My Mini has collected dust for over 6 months so I will be canceling.
Do you have a residential plan as well? Maybe they will allow in motion standby again with the plan increase. I haven’t received anything but we also have their Residential Max plan.Got an email today that beginning next month the price of Standby mode is doubling to $10/mo. I am sure the next move will be to charge you every time you want to reactivate. My Mini has collected dust for over 6 months so I will be canceling.
We do not, just the mini for when we are using the RV.Do you have a residential plan as well? Maybe they will allow in motion standby again with the plan increase. I haven’t received anything but we also have their Residential Max plan.
