I find that when I hit "0" that I can put in 55 gallons +/- - I have driven past 0 and put in as much as 58 gallons. I've never done that, not even on the stock tank bc as you mentioned below and from my previous powerstroke 6.0s, the last thing you want to do is run dry. But on the stock tank, stock programming, I have gone as low as 10dte. What capacity is your tank reprogrammed to?
Typically I am filling up before I get to 0 and take 50 gallons +/-. I find the OEM MPG to be about 1 MPG optomistic when I fill up and calculate by hand - it is usually about 1 MPG lower than the truck calculated mileage, so I usually factor that in when I get low on fuel.
I have recalibrated AFE Bias and it's within ±0.2 with the instrument readout and hand calcs (fuelly)
But figure my reserve is at least 5 gallons - but don't plan to test that unless in a pinch - as you don't want to run out in your diesel truck. Correct, how did you reprogram your tank size? forscan hex conversion (within the xxx-xxx-xxxx), the forscan drop down easy menu, or EZLink?
Are you hitting the same fuel station each time or various? If the same one, maybe try another - maybe they have optomistic pumps. Same 3 within the local area, typically
