S&B 60 gallon tank question
Lgm1970
Tremor Fanatic
Houston, TX
2026 Ford F250 King Ranch
2014 Jeep Grand Cherokee EcoDiesel
So i had the S&B 60 gallon tank installed on my 2026 King Ranch, I did not get the DTE module, the guys at Thor Off-road , who did the installation said not to waste the money and that they would adjust using Forescan. Has anyone done this and if so any issues of problems? It seems to be working ok, I know the DTE isn’t correct as I am assuming they can only adjust the tank size to 48 but not sure. The fuel gage itself is accurate. I was thinking about ordering the modular but not sure if it would be worth it at this point (my OCD may force me to do it..lol). Any thoughts would be greatly appreciated.
I feel confident that the ForScan changes allow for the 60 gallon size for the menu/dash displays. It's worth the effort to get ForScan and the ODB-II adapter for DIY, or find a local that has it all already, it's REALLY easy to use ForScan. You might even be able to find this option in Plain English menus.
I have the tank and it was adjusted by forscan for DTE
The highest it can be adjusted is 48 gallons. It can't go to 60. The tank will read Full for the first 12 gallons and your DTE will climb if you're doing a long distance drive or will read low if you do a lot of driving. It becomes more accurate when the tank gets to start reading normal. Also, keep in mind that when the truck get's to zero/E, you still have 8 gallons in the tank.
It's not annoying but it's annoying. Considering Titan can adjust the DTE via OBD2 connector makes the S&B module approach more annoying. I also didn't want to take apart the dash for it and others have had issues with software updates.
It also will take a couple of fill ups to calibrate itself to be mostly accurate.
good info!
I have an appointment to get mine installed and they said no problem adjusting the DTE not sure if it’s with Forscan or the Ford tool. He said they’ve had some issues with the S&B module. So advised against using one. Guess I’ll see in a week how it goes.
It's going to be forscan and it's going to set to 48 gallons which is the max that comes from the factory and is in the interface. There isn't a Ford tool.
Mine was installed at a dealership so they had access to everything.
What bothers me is Titan can be done via ODB2 port and is a 1 time update. I would have hoped S&B would have gone that route.
I agree that the module isn't needed as long as you know the tank will read full for the first 12 gallons and the DTE will be about 90% accurate considering there are 8 gallons in the tank when the gauge shows empty and the first 12 don't register.
Like others, I have mine adjusted to 48 gallons and although it is slightly annoying, I will live with it until an actual software solution is stood up.
There is absolutely no way I am plugging an aftermarket item into my trucks computer while it is still under warranty. Even if S&B says that it will not impact a warranty claim, they are not the ones making that decision. I am not saying this unit will cause an issue, I doubt it would. My concern is if there is another issue with anything connected to computer.
When a dealership files a warranty request with Ford, there is a very specific question they have to answer about any third party items/parts being present or connected.
While some dealerships may be cool, it may be out of their hands. Being cool and lying to Ford and possibly jeopardizing their business for you are two very different things.
Ford will most likely deny the claim, putting the burden on you to prove that the module didn't cause the issue. Good luck getting S&B to have their legal involved and fight Ford on your behalf.
The risk just isn't worth it.
My previous 2021 allowed for a 60 gallon tank in forscan settings, it was in plain English… however I believe that 2023 plus, this no longer shows in forscan and it’s only allowed to go to 49 gallons.
It actually started in 2022 MY when they changed the encryption. My 2022 had the 55 gallon titan tank and it was only adjustable to 48 gallon, which is still the max.
I wanted more capacity so I went with S&B only to find out they didn't have the update like Titan does. Had I known, I would have done the titan tank again which, might I add, has a better pick up reading on empty. When it showed E, you have 3 gallons left as opposed to the S&B tank which has 8.
Awesome, thanks every one. Thor did adjust it using forescan so I just keep it at that for now and maybe S&B will come up with a better fix or just get used to it. I wasn't crazy about connecting an aftermarket module and having to take apart the dash, Thor wasn't a big fan of it either and they mentioned that haven't had any issues or complaints. It hasn't been that bad but I also haven't gone through a full tank yet so maybe it will calibrate after a few fill-up....it takes awhile...lol, but its an awesome addition.
It does take a few tanks.
I was thinking about getting the titan recalibration tool since it would get me closer to 60 as a test. Their website says it only works with Titan tanks but I don't think that's true.
It actually started in 2022 MY when they changed the encryption. My 2022.
I wanted more capacity so I went with S&B. 🏆
I believe it actually started with the 2023. I have the S&B 60 gallon tank on My2022.
And by using the EZ Link, I was able to easily adjust for the 60 gallon tank. 🏆🏆
I had the guys at Thor do forscan for the tank on my 23 but it never took. Had to get the module.
