Reverse Level Questions
When you ask for opinions, you have to ready for any and all versions of the topic. I learned long ago that they are like A-holes everyone has them and they generally stink. It is op's truck and desire much more $$$$$$. If it is unsafe the I could see there being an issue. Alas lowering the rear is not unsafe unless were talking Carolina squat that should be avoided at all cost and punishable by death lol, jkg not death but castration absolutely! Just put the Whipple on it already and do your part to kill the tires of the world.
to be expected
Just throw 5 horse mats in the bed, then it will be 1" lower and ride better plus have more traction.
Braking will be a little worse, but you'll get to see if you like it.
Plus if you ever haul heavy just remove the mats and still be level.
Just throw 5 horse mats in the bed...
If you're able to, how about telling us which mat in particular you're using or that you are thinking of.
How much does that brand of horse mat weigh? Those fuggrs can be heavy. I like your idea, actually, but I have plans for my truckbed that do not include altering the suspension beyond a damper swap.
Cheers.
Cheers.
They are horse stall mats sold at Murdochs, Tractor Supply and other locations. And yes they weigh between 80-100 pounds each. Use them under a slide in camper. I'll take the $250 PMF reverse level over throwing the mats around any day.
A 1.5" reverse level is ideal and if you do need to bump it up just use some timbrens or torklift upper stable loads that engage the overload spring sooner.
light compartment mounts
I'm just sayin
buying a lift package, just to then lower the truck????
i don't get it??????
I'm not saying don't. do what you want to your truck. it's yours, do whatever you want. i don't care if you made a bumper dragging low-rider out of it.
it's just
i still wouldn't get it
go all out and put in a fully adjustable capability of setting it down on the bumper parked to whatever height you wanted while driving down the road or maxed up while rock crawling a trail.
that, I'd get
in fact surprised no one's done that.
$5k for an off-road lifted package.
then pay whatever to lower it, lighten the springs, etc...
beyond my comprehension or understanding
get power step running boards
just sayin????????
to each his own
and/or
whatever ya gotta do to keep the wife happy 🤣😂🤣😂🤣
a whole nother pack of issues there
It’s obviously beyond your comprehension. No doubt. Actually, we all pay the extra 5K just to have the Tremor bed decals. Duh!!!
comprehension
whats that?
i don't think i have any
you can get the decals for less than a 100 bucks🤷‍♂️. put them on a level truck & nobody would ever know the difference
i just don't get it???????
wow!!!!
guess i never will
good luck with leveling out your truck however you want it & i hope it works well for you're needs 🤞🤞🤞🤞
sorry for the troll
just caught me in a mood this morning
I'm out!!!!!!
comprehension
whats that?
wow!!!!
guess i never will
sorry for the troll
I'm out!!!!!!
All is good my man!
I ran a PMF 2" block for a week and it was fine, but after two weeks I went back to OE block and installed a Carli leveling kit.
I'm probably gonna end up going this way
Trying to figure out if I can put a set of std or hd’s Deavers under the rear, from what I can find on the inter web it would lower the back about an inch with no blocks.
Are all you guys using just PMF blocks to reverse level? If not what other blocks do you suggest? If I decide to add air bags down the road do I have to buy the PMF air bag platforms or are they not needed.
I went with the air bag platforms also.
Which air bags did you go with? I'm looking at Either the Air Lift bags or the Retrue ones. Did the air bag platforms make a difference?
2025 Tremor... Looking for some input from those that have done it and pictures if possible. Still torn between going up in the front or down in the back.
1.5 or 2" block? I'm pretty set on 1.5 but I'm curious to see pics of both if possible
What airbag kit works with it? I do tow an enclosed trailer (about 7-8k lbs) pretty regularly.
Should i run shorter shocks in the rear? If so, can I run the non resi fox 2.0 on the back and resi 2.0 on the front without issue? I'm assuming they are still valved the same. I may also run the 2.5 HTO's if anyone has input.
Would it still be possible to run a 37x12.5 tire on a +1 offset wheel? If not, what offset may work, if any?
Please share any other input, pros and cons, etc
I just did the Carli shackle kit and the shop had a pair of stock rear blocks from a non Tremor f-250 which is 1" lower than the Tremor blocks. Now measuring from the wheel center to the top of the wheel well arch the rear is 1" higher than the front. For the breast reduction critics my truck just fits under the garage header and if I lifted the front to sit level my truck wouldn't fit in my garage.
