G
Guest2475
Guest
According to PMF it is dependent on your lift as "some lifts will cause the tire to bottom out before hitting the bump stop". If you're running stock suspension with a 2" block, it may be a good idea to get the bump stop tang so your tires don't bottom out.Do I need the Bump Stop tang and the 2" blocks?
